5960X Uncore thermal impact: Stock vs OC
Testing Uncore and its impact when loaded with controlled temps.
On auto the uncore trains in at 1.55v @ 4500Mhz but I found that the uncore can actually run that speed 1.35v to 1.4v
Shamino also mentions in his OC guide that over volting the uncore is preferred.
From what I have seen so far, these uncore speeds are only possible on the OC Socket.
If your motherboard does not have the OC socket it will not reach these speeds.
It should be possible to run 4.5Ghz uncore 24/7 on air safely.
The setup:
Intel 5960X USA
Asus Rampage V Extreme X99
Corsair LPX DDR4 2666C15 SPD and XMP
Nvidia 750ti
Enermax 1500W PSU
Cooling:
Theraltake Ultimate Water 3.0
http://www.thermaltakeusa.com/Cooler...ate/design.htm
GE 8K BTU AC Unit forced into radiator
BIOS:
vcore 1.000v
vmem 1.2v
vcache auto 1.55v
cpu 40x100 4Ghz
cache 3000Mhz, 4000Mhz, 4500Mhz
Stock speed, memory at SPD = lightest load
http://fugger.ipage.com/x99/cine1.png
Uncore 4000Mhz memory at XMP 1T
http://fugger.ipage.com/x99/cine2.png
Uncore 4500Mhz, Mempry at XMP 1T
http://fugger.ipage.com/x99/cine4.png
