2 Attachment(s)
Building my first Single Stage
After 10 years of inactivity I decided to come back.
I had an old Single Stage made by "Unseen" in the basement that was not working any more because of a leak.
I decided to try building my own Single Stage
I used:
Danfoss 1/3 hp with R404a
Condenser 140x140x90mm
Evaporator Asetec Vapochill LS
Desuperheater Coil
High Pressure Gauge
Filter/Drier
15ft captube
Case, I used an Freezepack made by Unseen back in 2008.
That was the compressor, condenser and evaporator in the old Single Stage...
https://i.ibb.co/smRQ1S4/IMG-20190706-171354.jpg
This is the final result
https://i.ibb.co/J2NHyJM/IMG-20190706-152755.jpg
https://i.ibb.co/KqhjVVR/IMG-20190706-152439.jpg
https://i.ibb.co/17CMqHF/IMG-20190706-152549.jpg
https://i.ibb.co/cTJhLCZ/IMG-20190706-153222.jpg
As regards temps, idles at -55 C and with Pentium E5800 @5.0GHz at 1.7v after 27min of load keeps - 47 C.
https://i.ibb.co/JC0dfSw/IMG-20190528-151859.jpg
