Wow, this place is quiet! Well, I am headed back onto the breach! Wanna build a ryzen 7 system. What company is big these days? I used to use all Swiftech.
Probably the most popular these days:
Blocks - EK
Pumps - Swiftech/EK/Alphacool based on Laing (not much has changed here)
Tubing - Primochill
Radiators - Hardware Labs / EK
Check for Optimus water cooling too !
If on a budget xspc , barrow and bykski are great alternatives , great quality , performance and lowest price.
What kind of coolant and additives would you recommend for the longest 27/7/365 operation before having to drain and clean a custom loop? And how long would that be before doing it?
Cool...thanks.
Woooo old timers
:D
Whats up peeps ?
Being covid 19 free, I figured I join the club. Just spent 2 days at Morongo Casino, Cabozon CA. Good fun.
We'll see if i survive.
10 bucks I will :)
OPP
I think the Casino is what brought Covid to Vegas and where I first caught it back in December
Funny i just logged on from who knows how long ago . I remember some of ya'll . I am def getting back into water cooling as well and doing an AMD build after their new stuff releases.
Damn its been forever. Just logging back on myself. I'm 90% finished a new 10900K build with dual 360 rads, cpu and gpu.
It's been years, I feel so out of the loop!
Been struggling with temps on a W3680 (don't judge, 6 Cores at 4.x GHz only just became mainstream, welcome to 2010, you're going to love it) since adding a GPU block and extra radiator. Probably going to go dual loop.
https://i.redd.it/i509qwfgona51.jpg
So, I discovered my old pump from 2011, booted right up! Put in a Monsoon DDC Reservoir, it started making a grinding sound, and died. LOL!! okay.
My system from 2013 is running like a champ! Monsoon dual bay res gen 1, 420 Swiftech QP, 320 Swiftech QP, 220 Swiftech QP, various fittings, primochill tubing, Kamodo block for the 7970 and Apogee Drive CPU/pump.
I don't think I should risk using this pump for this new build, it's 7 years old, and still works, but it's 7 years old!
I got a 5700 Liquid Devil, 18 Monsoon compressions fittings, a Monsoon Dual Bay, Gen 2 with DDC mount, new Primochll tubing, and PWM fans. I need my new CPU and MB. It's cool to be back in the game! Hello everybody!
