Nikon DSLR with sub-zero Peltier cooling
http://arstechnica.com/gadgets/2016/...my-less-noise/
In my 20-odd years of PC building and DIY electronics hackery, I have attached refrigeration units to many things: overclocked CPUs, of course, the underside of a mousepad during a particularly hot summer, and once I even made a hand-holdable single-beverage cooling device. What I've never even thought about doing, though, is strapping a Peltier cooler to the back of a digital camera to capture higher-resolution low-light photos.
For ?2,190 (?2,000/$2,400), the Italian company PrimaLuce will sell you a Nikon D5500 DSLR with a dual-Peltier cooler strapped to the back, called the Nikon D5500a Cooled. In addition to the cooler, the modified camera also switches out the standard low-pass filter in front of the sensor for something that is specially tuned to be more sensitive to astronomical wavelengths of light (specifically H-alpha deep red). In case you were wondering, a normal body-only Nikon D5500 currently retails for about ?400/?500, so you're paying a fair ol' premium for the modification.
The cooler itself is a Peltier capable of refrigerating the sensor down to -27 degrees Celisus (-16.6F). A Peltier cooler uses the the Peltier effect to rapidly pump heat away from one side of the cooler to the other side, where there's a heatsink and fan to dissipate the heat. Peltier coolers are incredibly power inefficient, but they're compact, and unlike standard vapour-compression refrigeration have no moving parts or circulating liquid. Back in the olden days of overclocking Peltier coolers were all the rage, but the massive power requirements?provided by an expensive, separate power supply?made them unwieldy.
There are some buttons on the back of the cooler that let you adjust the target temperature. Since the refrigeration could cause the front filter to dew up, especially in high-humidity environments, the modified camera also includes an anti-dewing system that heats it up slightly. One small issue with PrimaLuce's camera, though: the Peltier requires an external 12V 3A power source, which isn't provided. Presumably you'll need to carry a big battery with you, or be tethered to your car or house.
Look closely (you may want to click the image to zoom in) and you'll see a ton of noise (red, green, blue speckles) on the right hand side.
The graph on the left shows you the effect of the modified filter on the cooled camera, making it more sensitive to certain frequencies of light.
https://cdn.arstechnica.net/wp-conte...freddata_1.jpg
