Finally some data - after 7 attempts to run the XSPC block I finally have good data and can move on to another block! Tested at +100mV, +100mV aux, PT1T no throttle bios, 1150MHz core.
Bear in mind this data is on the replacement GPU and can not be directly compared to the previous data. As always look at the axis - I keep the scale (1C/division) the same, but the X axis does not cross at zero and the crossing point moves in order to show the data better. Oh and the Y axis text needs fixing to match the chart title.
http://i.imgur.com/q7c3CYv.png
As expected the backplate makes little to no difference to core cooling. VRM cooling is a different story:
http://i.imgur.com/pchuaZ1.png
VRM1 is the inbuilt sensor near the main VRM section near the power connectors. This can be measured with GPU-Z or hwinfo. VRM2 on the other hand is near the monitor connector end of the board near the memory. It is cooler as it runs less power:
http://i.imgur.com/I0X62Ue.png
Now just to make sure there wasn't anything funny going on with VRM measurements as AC's results from before looked suspiciously good with a backplate I added a probe near the VRMs manually (see post a few up). This as expected tracks VRM1 but a few degrees off:
http://i.imgur.com/v2HlpTB.png
Conclusion - the XSPC backplate seems to make VRM cooling worse! This is not a surprise when you realize that XSPC do not use any thermal pads on the backplate unlike AquaComputer or EK for example. Despite this the VRM's are still cooled acceptably so it's not the end of the world.
So now to move on to the watercool block and then to retesting the other blocks.
