yes, cpu and nb maybe gpus someday.......
Ok... ZALMAN TEST RESULTS.
P5N-32-E-SLI-PLUS with Q6600 (Stock Speeds for Test)
Single 8800GT (NO OC for Test)
Ambient Air Temp 20 Deg.
The test consisted of 5 Back To Back Runs of Futuremark 06.
Stock Cooler Stock Fan Speed (out the box as it were)
No Load after 10 Min
50 Deg C
Futuremark Passes max temp
1. 74
2. 77
3. 80
4. 82
5. 82 (If I did more tests, I believe it would keep heatsoaking higher)
VF-1000 60% Fan Speed (Set from Bios)
43 Deg C
1. 50
2. 52
3. 52
4. 52
5. 52 (No Crap There...)
That is a "Delta" of 30 Degrees LOWER... Unreal!
Remember, this is only 60% Fan Speed. It is dead silent and performing Very Very Well.
I did not test the stock cooler at higher speeds because it becomes REDICULOUSLY LOUD.
I have had this product twice now, Once on my GTS and now on the GT. I am completely impressed with the performance and looks of this.
Please spend the money, it's a No Brainer Upgrade. Don't even think about it, just buy it.
http://img2.putfile.com/main/11/33315572064.jpg
http://img2.putfile.com/main/11/33315572230.jpg
http://img2.putfile.com/main/11/33315572217.jpg
http://img2.putfile.com/main/11/33315572325.jpg
http://img2.putfile.com/main/11/33315572383.jpg
http://img2.putfile.com/main/11/33315572444.jpg
http://img2.putfile.com/main/11/33315572487.jpg
http://img2.putfile.com/main/11/33315572410.jpg
http://img2.putfile.com/main/11/33315572432.jpg
http://img2.putfile.com/main/11/33315572183.jpg
http://img2.putfile.com/main/11/3331557219.jpg
http://img2.putfile.com/main/11/33315572281.jpg
http://img2.putfile.com/main/11/33315572296.jpg
http://img153.imageshack.us/img153/2...ture199fw5.jpg
Its kinda dusty.
Before this Zalman i had an ArcticFreezerpro64.
Dont see any difference in temps though.
Actually i just ran the dryer duct yesterday as i am F@H and its cold here:)
My air cooled rig!
http://img529.imageshack.us/img529/6231/seap1.jpg
[]'s
Simps
On cpu, Thermalright Ultra120 eXtreme with Noctua NF-S12@900rpm atm:
http://img148.imageshack.us/img148/9...e001ti9.th.jpghttp://img148.imageshack.us/img148/1...e002bo1.th.jpghttp://img99.imageshack.us/img99/832...e003gi0.th.jpghttp://img148.imageshack.us/img148/2...e004wt0.th.jpg
Awaiting Scythe S-Flex for TRUE120.
In case, 6x CM Red Silent 120mm, 1x200mm Antec, 1x CM Red Silent 80mm:
http://img150.imageshack.us/img150/1...e001bi1.th.jpghttp://img150.imageshack.us/img150/6...e002jl0.th.jpghttp://img144.imageshack.us/img144/1...e003xx4.th.jpghttp://img144.imageshack.us/img144/3...e004eu8.th.jpghttp://img144.imageshack.us/img144/5...e005ax2.th.jpghttp://img227.imageshack.us/img227/3...e006rc2.th.jpg
I've since moved the fan to the right of the heatsink:p:
http://i75.photobucket.com/albums/i3.../Picture-2.jpg
Brian MP5T & Simps, are you guys using any heatsinks for the PWM area?
it's a two phase analogue PWM, where you can see 2X 3 sets of the MOSTFETS together, thats them, without any heatsink I tested with my IR sensor around 90-110 degrees, and immediately took the cards out to stick a heatsink on them.
Very nice mad_skills
I have an P5N-32-SLI-PLUS.
It had heatpipes that went from the NB and SB to Banks of Fins that were on the Mosfets by the CPU.
When I removed the Heatpipes, I left the Bank of fins where they were..
http://www.hardwarezone.com.au/img/d...p5npre_top.jpg
Just added HR-03 and HR-11 to my R600. Dropped 30ºC... Thermalright is Teh Pwnage :D
Phone pics FTL...
http://img338.imageshack.us/img338/8...1resizeca6.jpg
http://img338.imageshack.us/img338/4...presizeiu7.jpg
http://img47.imageshack.us/img47/837...3resizenx6.jpg
http://img137.imageshack.us/img137/8...2resizewt2.jpg
Behave!
Nice Brian, I see you've gone from your thermaltake CPU heatsink and used the cnps9700, good on ya ;)
Here's some pics of my recently lapped Tuniq and E6750. My first time doing it. Went 320 -> 600 -> 1500 grit. I was completely surprised that I didn't fry my CPU. That said, if I didn't fry mine, no one will.:up:
http://i48.photobucket.com/albums/f2...ld/Lapped2.jpg
http://i48.photobucket.com/albums/f2...ld/Lapped1.jpg
Try and find 2000 and 2500 grit.
It makes mirror finish without need to polish the base.:up: And will make your Tuniq even better for sure.:up:
I used 320/600/1000/1500/2000/2500 profiles on my old HyperTX and look what mirror you get:
http://img89.imageshack.us/img89/257...e001py7.th.jpg
http://img88.imageshack.us/img88/3191/img0013io9.th.jpg
My new Asus P5E Mobo should be arriving tommorow :)
I will post pics of it and my build asap!
Gosh it's quiet
=o
RIGHT HERE WE GO
Upon waiting for my P5B Deluxe to be returned from Asus... I knew I was going to wait a while, meanwhile I couldn't stand it after a few weeks of having crysis but couldn't play it, so I went ahead and spent some money on a new X38 mobo :)... My Asus P5E had arrived.
Here are some pics of the mobo and my build when it was finally finished:
http://i80.photobucket.com/albums/j1...d1337/p5e1.jpg
http://i80.photobucket.com/albums/j1...d1337/p5e2.jpg
Beasty Heatsinks
http://i80.photobucket.com/albums/j1...d1337/p5e3.jpg
http://i80.photobucket.com/albums/j1...d1337/p5e4.jpg
http://i80.photobucket.com/albums/j1...acketfiled.jpg
Oh yes, and there was a problem when I was fitting my CNPS9700, from what I gather it was a support clip that is used when putting the cooler on a AMD mobo. I ended up having to file it down so it could squeeze in with all them heatsinks :D
http://i80.photobucket.com/albums/j1...7/black-io.jpg
Lovely Black IO shield plate with padding on the other side! (sorry I forgot to take a pic of the lovely padding)
http://i80.photobucket.com/albums/j1...pclightson.jpg
Ta da! Ops slightly blurry
http://i80.photobucket.com/albums/j1...7/DSC02322.jpg
http://i80.photobucket.com/albums/j1...7/DSC02323.jpg
http://i80.photobucket.com/albums/j1...7/DSC02329.jpg
http://i80.photobucket.com/albums/j1...7/DSC02327.jpg
http://i80.photobucket.com/albums/j1...lcddisplay.jpg
22.7'C on my HDD, 56'C Threshhold before the alarm goes awol
http://i80.photobucket.com/albums/j1...ntroller-1.jpg
Green UV Springs for watercooling hose, but I used them on some of my cables :)
As for the moment i've only got my E6600 @ 3.06GHz, 1363fsb, 23'c idle.
But tommorow, after i've fixed a few audio issues, i'm going to reach alot higher.
Sorry if there was to many images.
Next on my list is a 8800GT or a GTS Rev.2 to replace my sketchy ATI Radeon X1800 XT
Please comment :D
