Where to Put Two Subwoofers.
I'm going to be using two subwoofers with my home theater. I was wondering is there a good way to set them up?
* Run each of them on one side. What I mean is.. Run one subwoofer off the right front speaker, and one off the left front speaker.
* Run a splitter for each Sub.
* Just use the two outputs provided by the receiver for both subs.
Once that is decided, I've heard it's best to have the subs on opposite sides of each other. Unfortunately do to the room design this wont be possible. Are the other beneficial options? Thanks!
