There is another way to restore your RAID array if a disk dropped out. If you have a hardware failure on one of your disks, this way won't work, otherwise it should be fine. It worked for me three times. Note that this way also won't work if your windows install is on the raid array you're trying to recover, because then your pc won't boot.
*I am not responsible for any data loss blablabla, I'm just giving you a possible sollution; from my experience it tends to work*
1) Enter the Ctrl-I configuration utility. Write your raid level, array size, stripe size and everything else that can be configured on a piece of paper, you'll need this info later.
2) Delete the Raid-array. Yup, that's right, just throw it away.
3) Reboot and create a new array just like your old one. If you do not use the full disk for your array, make the array slightly (0.5GB or so) larger than the old one, so you're sure the old one fits on the new one.
4) Reboot. Don't enter the drive system manger panel in windows. Download and install testdisk.
http://www.cgsecurity.org/wiki/TestDisk
5) Start testdisk. The program ask you whether or not it should create a log file. It doesn't matter for all I know, so choose whatever you like. Select your brand new raid array. Select 'Intel partition' if you have a regular
Windows partition. Next choose 'Analyse', then 'Quick search'. If your old array doesn't show up, try 'Deeper search'. Now your partition should show. Select the old partition and press Enter, then 'Write'. Testdisk now
writes the old partition table on your new array.
6) Close the program, reboot and everything should be fine.
This is how I always do it, might be worth a try.
