I used the tweezer method
I used the "tweezer method" with two 15 Watt soldering irons-----worked like a charm for me AND left a lot of solder on the R50 pads.
I practiced on an old circuit board about three times before I had it down pat-----and I let my irons heat for 15 min before I even tried.
I did not use ANY solderwick as I was afraid I suck up all the solder off the pad.
I then added a small drop of solder to each pad.
Using the drop of solder and the way it came off my iron----it actually built up each pad to a small little "tower"-----which was much easier to solder the individual wires to.
I got a lighted magnifying, swing out, workbench lamp to help-----it was invaluable as the parts are REALLY small.
John
