http://i82.photobucket.com/albums/j2...phen/3400a.jpg
my 1st trial run today,
air-cooled with Tower 120. :)
wow :) nice run. What mobo do you have?
Wait, what? (feels like cold water to the face)
Nice overclock, is that 4 core load stable? Voltage seems a bit dangerous though.
790GX..... Does that board have the SB750 Southbridge?
Seems like I read that it did... :D
Very nice overclock:clap:
You have overclocked through AOD I reckon?
How does it overclock through bios?
w00t:D.
Did you try that Phenom on a SB600 board before by any chance so we know there's a real difference or you just have a good CPU:p:
Also did you get this board for preview or anything like that? Or did you really buy it? Cause if that's so, I hope we can expect them really soon then:D
However, as others said, better use Prime95 to test stability there. AOD stability test is really worth :banana::banana::banana::banana: all.
nice clock matey,
but i would hold back on that Vcore, @1.55v i found the Phenom stable but the heat under load (with water) just kept getting higher, slowly but surely.
i dont think you can get the Vcore above 1.45 -1.50v without this problem,
what version of AND Overdrive are you using? i see beta in the info bar? new beta?
EDIT: found the beta: http://downloads.guru3d.com/download...a60f2028038472
i shall give it a go
Heh, what has that do with my post:confused:. I dont get it:p:
But did you buy this board or did you get to review it early? And did you use your Phenom on a different motherboard with the SB600 as well? If that is so, does the SB750 fixes all the problems that are on the SB600?
Thx in advance:D
PS: One of the very first motherboard manufacturers besides the Quantum Force from Foxconn to post their SB750 boards in their product list. Looks like they added -Ultra to the boards with the SB750, they fixed AMD 790X, 790FX and RS780D:D Aren't J&W and Jetway more or less the same anyway?:confused:
by the way, I tried the same vcore for 3.5GHz.
not stable anymore.
so sb750 finally or not??
Stephen any chance of providing the picture of the mobo?!?
It kinda sucks to see many websites using the AOD i leaked and not give credit to my website or myself, i've seen this in a couple of "websites" already. They didnt even put it on the news but they sure used "my file".
For AOD to overclock a lot you need RD790+SB 750 or RS780D+SB750 with a Black Edition Phenom.
