best chip did 270 -70 ss and 273 LN2 :ROTF: @ 1.49VTT max settable with normal bios
Is this the bios sir hiwa ?
i tried 9A and 10A
http://forums.tweaktown.com/f69/giga...st-bios-28441/
and here
http://forums.tweaktown.com/showthre...374#post274374
is the list i can see here
GA-H55M-UD2H - F5m
GA-H55M-UD2H - F9a
GA-H55M-UD2H - F9d
GA-H55M-UD2H - F9g
GA-H55M-UD2H - F10a
Im going to try F9D today, just downloaded it from tweaktown aswell.
Hope i can get that VTT going, els it´s a waste aswell.
oh well, we´ll see!
please let us know maybe special bios was in the list and i didn't try it ? :D
Very interesting things I see here :) Wait for good result without spesial BIOS and mods.
will let you know hiwa, what settings did you try for that 272bclock?
rly high pci-e freq or, what helped you?
SS
250 X 15
Vcore:1.50
VTT:1.49
VPLL :auto
PCh: 1.10
PCI ex freq don't help for higher bclk on clarkbar as i know but i setted always 105
2:6 mem cl9 1gb single channel stick
qpilink i tried 20X to 32X (board is cool with high qpilink i tried 40X ;))
disbale all onboard/cpu futures etc, tried all cores
Sexy dino will help us when see this thread for sure ... :p::p::p:
going to flash the F9D bios now atleast, fiddle a bit on AIR first, 'unknown' with the whole H55/P55 platform right now.
will keep you posted. thanks for the settings, good push in right direction :) got 25/30L LN2 left, hope my mobo can deliver. or bios can deliver..
//edit
Hiwa, i flashed the F9D, says same as #52, toolius. i will try,but what happend when you set over 1.5V VTT, it just wont boot or?
this bios i flashed: http://download.gigabyte.us/FileList...m-ud2h_f9d.exe
//edit2
Nvm, this bios also cant select above 1.49V VTT. would be nice if someone could share, but i dont think any public bios will go higher then 1.5V , unfortunately.
Wonder how 2/3 people here got them then :p ...
same here max vtt is 1.49
i'll check, maybe we can can hardmod it ;)
Hmm, testing on air for a bit. i've gotten up to 245block on air now, but crappy part its 2:8 mem divider :( , i boot @ 220 bclock, and with 2:8 mem divider i can get up to 245 and even higher i suspect.
2:6 mem divider when i try to set at 223mhz bclock instant bsod. Lame. i dont have that crappy memory, but i dont think i can do 2250+ mhz with decent timings.
Dont think cold will solve that issue :S , will try more, but lame :/
i tried the f9D bios too and no luck :( :(
wish we had that unlocked VTT bios..
going through every bios in your list sir hiwa and will see if i find something !
cheers and kind regards !
Maybe there is some hard mod to this board for high VTT ?
in this thread below i3-530 on same UD2H board has hit 6.73Ghz and is using the same bios F9D
http://www.xtremesystems.org/forums/...4&postcount=25
Hope we can figure this out :)
cheers and kind regards everyone !
i can't catch Dino to ask, that one should be HardMod OR GOLDENXXXX 530 ;)
no luck yet, i did do CB/CBB mod, still i had -100CBB / -120CB , perhaps mod wasnt good, will try again.
didnt get above 260mhz bclock :( , freeze above that. which is crap!
Will try the other cpu, perhaps if that works better or w/e , but this is crap so far..
thijs you have to try more cpu than one )
yes, will try tonight other cpu. but dont think i was limited due cpu, havent found good settings yet for for mobo, i think..
allright .. got a i5 650 , 2x 661's and a 670 and going to try as well this weekend
But it looks like special bios or hard mod to get more than 1.5v vtt .. so no chance of really pushing.. but will try for max bclk with 1.5v VTT
Hope Sir Dino sees our plight :P
testing a bit more, new cpu. this one, or perhaps i soldered it better now, has CBB/CB @ -160. didnt get above 265block yet.
But it doesnt like booting with high QPI voltage, anything over 1.30 - 1.35V it wont boot. really low QPI freq wont boot either, 12x or so.
or isnt that a limiting factor, 24x @ 260 or so is like 6,5ghz. isnt that too high?
http://rapidshare.com/files/404186621/h55mud2h.rar.html
vcore up to 2.1v, VTT up to 1.60v
:D:up:
that why i love sexy dino :D and hate hicookie :ROTF:
i think the password is sexy dino
thanks for sharing dino s22
:D
if there was no cookie you guys would never have this bios :rofl:
you can still love me all you want :ROTF::D
here's a new one
http://www.filefactory.com/file/b25d...re_amp_vtt.rar
