Hey Shoggy, thanks for the pics. Can you tell me if there will be any mixed metals in your product or is it completely copper/delrin?
Metals are the same as all our new blocks: nickel plated copper. :)
Its an acrylic body like our VID-398GX2, very similar actually. Biggest difference is that the nozzles will exit the block parallel to the board rather than perpendicular such as our 9800GX2 block.
I don't have pictures right now, but its one of my favorite video card blocks :D
Shoggy -- What US Distributers will get this first?
Shoggy, I really am liking the design of Aqua Computer's 295 block. It really looks nice and very flexible. I wonder if the stock casing can still be put on afterward. hmmmm
@dorian: I think Sidewinder Computers will have them first.
@BlueAqua: nice idea but that won't work.
Which inputs are these blocks going to have the three plugs on the side or the usually sli plugs?
God, I don't know which to choose!!!!!! I just got my gtx 295's and While I really like the design on your block shoggy, I just got rid of my EK 9800gx2 blocks and I liked how they performed! Plus on my x58 board the Swiftech SLI fitting worked perfect with the cards right next to each other. The way the fittings connect to yours it wouldn't let me do this, but eddys blocks look like I can do the same thing!! By the way Eddy, your 9800GX2 blocks rocked!! Keep up the good work! :D Although, Dean, your blocks would be mighty sexy if the fittings were vertical!
WOW is there a problem with saying quad sli is broken? because quad CF is too.... I was just saying before that the 2 280s are better generally than 2 295's, but then I was reminded andy is using them for crunching then obviously 2 295s are better.
why do you constantly say i'm trolling? is it because you think that quad SLI isn't broken?
Hey guys,
Take a look here:
http://www.aqua-pcs.co.uk/nvidia-gpu-blocks-280-c.asp
They look very tasty!
