You guys will do fine, Im sure you all will get some sweet results, everybody on the list has more than enough knowledge:up:
good luck!:)
for me too big leap :-)...i hope, OC team Slowakia ( www.ocmag.eu ) help me with this.
I dont know now exactly, because it will in 1H 2010 with helping OC-mag team at "lanparty":)
Don't cut yourself short yet:p: We had some good results under tame cooling.:up: I am going to do some stock air test first thne under the Xig dark knight. After my new water mod, it will be next. I just put F7 bios on the UD5P... Chew* if your reading, have you tried it yet? Good luck all.
The pot in Simon's avatar is extrememly similar to the variant I use. I am continually working with the designer to improve upon it and its performance and make it universal. The variant I use is in my avatar ;) It does extremely well on DI as well and we have a water cooling conversion in the works for it :)
Yes lots of new fun stuff being worked on at LN2cooling :)
New Prolimatech Mega Shadow (Megahalem) Nickel Plated "Black Edition" & Delta "Mega Fast" 120mm x 38mm Fan - 252 CFM will be here on Wed so Air Cooling tests can start with that while my Phantom is away on vacation :rofl:
hm...Megahalem or Xigmatek HDT-S126384 Thor's Hammer ? I will for x6 Thuban better Xigmatek
