Asus P5K Deluxe Wi/Fi with SILVERSTONE ST75F 750W PSU Not Compatible??
Ok. Here is the deal.
I just installed a new Silverstone ST75F PSU into my P5K E6600 system. See the spec's in my sig. This system works fine with a Real Power 550 - RS-550-ACLY PSU.
I ordered the ST75F a couple of weeks ago and installed it. It didn't work. When I power it on it acts like the 8-pin ATX12V isn't connected. It slightly gets power, fans slightly turn then the system shuts off. The MB power LED is green, the 24-pin motherboard connector is connected, the 6-pin PCI-E is connected.
I've tried the 4-pin ATX12V connector instead of the 8-Pin with the same results.
I RMA'ed the first PSU 2 weeks ago and got a replacement yesterday, installed it and Bam.... The same thing. Flash of power then nothing.
If I try to restart after the immediate failure then it will not do the slight power the shut off. I have to unplug to remove power to the MB before it will try the slight power thing again...
Once again, I put on my Real Power 550 - RS-550-ACLY 550W and everything fires right up.
Could a PSU and a MB be incompatible?
Is anyone running the Silverstone ST75F PSU and the ASUS P5K Deluxe Wi/Fi with success?
http://www.newegg.com/product/produc...82E16817256009
Thoughts?
-Surly
