Yea I thought so, man those WD6400AAKS, looks very tight!, the Samsungs are looking good to, but I am abit skeptical about those "F1 problems" any1 know if it is solved?
WD6400AAKS x 2 - RAID 0 results:
http://www.xtremesystems.org/forums/...7&postcount=15
Single 6400AAKS short-stroked:
http://i13.photobucket.com/albums/a2...itionbench.jpg
~Ibrahim~
I built my new rig last night and put 2x320GB WD AAKS in RAID 0. I installed Vista in 14 minutes!!! I was quite pleased. Plus those drives and the 640GB WD AAKS are whisper quiet! :up:
So here are two WD6400AAKS on intel matrix raid. One RAID 0 slice is 200GB (for OS) and the other one with all remaining GB's is 1TB RAID 0 slice. Benchmarks are done with HDTach 3.0.4.0 - Long bench 32mb. Both "slices" have stripe size of 64kb.
Slice No. 1 - 200GB
http://www.xtremesystems.org/forums/...1&d=1209364424
Slice No. 1 - 1TB
http://www.eoz.lv/forum/attachment.p...1&d=1208895227
Niiiiiiice. :)
~Ibrahim~
is it possible that u stripe 1 part lets say the first part of the HDD in RAID under RAID0 and the rest striping it as RAID1 for storage purposes?
In the case u are getting 2x WD6400AAKS
thanks jj!
see more results // access time bellow 8sec: http://www.xtremesystems.org/forums/...9&postcount=21
for more comparison heres 4x 6400 @ 128GB on highpoint rr3510
http://img166.imageshack.us/img166/7100/33bi3.jpg
^^ Nice results NapalmV5!
How are you liking the rr3510? I was thinking of a similar setup
nice performer.. so far so good.. no compability problems yet.. no guarantees though
What mobo/chipset are you on?
asus maximus se/x38
Im gona bump the thread, im looking for 2 drives, and was about to buy 2x F1's, but it looks like the AAKS are killer, or did i missunderstand something.
And btw, is the F1 reliability issue solved?
And a last thing, what abot the WD Black series?
Between the Samsung and the WD, get the WD 6400AAKS.
Ok, and any comments to my other thread? LINK
And you say "Between the Samsung and the WD" are there any other opportunities that are worth considering?
