I am proud to help! ;)
Does this work with the 3870X2?
Need some help with this....
First thing is that my winflash would not open in windows, so I guess I need to flash throu dos and a floppy...
Is it just to have a floppy disk and download this "FLashRd ver.3.0"
I have a original bios at my computer, so I just copy my bios to this floppy an run it?
Does this program overwrite my bios no mather what?
I hope so, becouse my video card is dead now... I am using a PCI card and I have my dead PCI-E card in the PCI-E slot aswell.
Please... All help is needed to see if I can get my card alive again.
My card die when I was flashing it, then my computer went off... by power issue or something else... in the middle of my flashing...
I have downloade a original bios for my card and I have using RBE to get my original bios and one from GPU-z... All 3 bios is the same, I checked it out yesterday, and all 3 working in my card... did flash it and try them out yesteray
Well I dont know if it is the bios but i can guess... my card is 3 days old, and it went dead after i failure in flashing it...
So my last try before i am throwing away my new card will be to see if I can get it to work again by flashing it by a boot floppy... need something that can flash my card with my original bios by floppydisk... and need it to flash it what ever it take...
If there is no program that can not handle that, then its nothing to do. =/
a new ATI card... do you know any program that can do what I am looking for?
If it not working fine, I will throw away my card anyway...
But if this last thing is working then I keep my card.
Just want to try it out... And I belive ther is som program that can flash from floppy, I just dont know how and so on... therefore I ask for some help to let me flash it by floppydisk... a last desperate try...
You need to be more descriptive, "new ATi card" could mean a lot of cards if there was old stock where you bought it, let alone many different performance levels of cards.
If its a 4870 then you probably flashed bad bioses. Most of the bioses on the web are truncated in size and should be 128k (they are only 64k).Quote:
If this is the case, go here (it is stickied at the top of this forum): http://www.xtremesystems.org/forums/...d.php?t=192986
How may times do I need to ask in this forum ???
Do u know any program that I can use on a floppy that can flash my card on boot no mather what?
Do you not know it or what?
I am maybe at wrong forum then...
Hi, I need help///
I have 2 - 2900xt's that i purchease from a reputable seller and i didn't fire them up for about 2 months till i got a crossfire board.
So now i got my board and I go to fire them up and it just sits there, everything looks ok, got a 6pin and 8pin from an 950w PS
also put a new cooler on one to keep it from getting so hot. But the board won't even go to bios.
So i put in another card (8500gs) plus the 2900xt and boot from usb. run atiflash -i and get no adapter found.
Board using is a Asus blitz Extreme, but i also tried the cards in a DFI x48 and still exact same thing.
Now i don't think i was ripped off but i think it's a bad bios or something like that.
I would love to get these cards working, i even have waterblocks for them....
any help would be greatly appriciated....
Regards
steve
Well... than I have some problem.... when using atiflash -i
Then I se some error...
I try the atiflash -i in my command line now in windows...
I was hoping on that any program can force flash it...
I dont need it to check or read my bios before flashing it...
Need to force flash in my original bios.
Maybe I can do a image and show u my errors... ?
http://www.kiptanoi.se/flash.bmp
hum thats weird. That is exactly the same error I am getting when trying to flash my working 4850 in dos using a boot disk and atiflash.
What version of atiflash are you using?
