CodeOfficer build
CodeOfficer has been a good friend of mine for years now and was always a Mac guy. With him in mind when I decided to start producing truly unique custom cases that would appeal to a range of high-end users from the do it yourself like me and mostly likely you the xtremesystems members, to the guy who wants a unique high performance system made for them. The cases is made of white acrylic and we all know that Mac users are attracted to shiny white plastic like flies to.... Anyways here are some of the pictures. More to come soon.
Lets start with the water cooling goodies
http://i1156.photobucket.com/albums/...-39-25_308.jpg
The radiators, pump, and CPU block were all painted to match the case
http://i1156.photobucket.com/albums/...-39-17_247.jpg
This was a shot of when I had just plumbed the system and started leak testing
http://i1156.photobucket.com/albums/...-56-57_119.jpg
I'm not a huge fan of macs myself but that cinema display sure is pretty and worthy of this system
http://i1156.photobucket.com/albums/...-21-35_820.jpg
A front view of the case. (better pics to come)
http://i1156.photobucket.com/albums/...-21-59_893.jpg
This system was purchased to play Guild Wars II so the back panel was engraved with the Guild Wars logo and hand painted by my artist gf
http://i1156.photobucket.com/albums/...-22-38_621.jpg
Very nice pieces!
I'm not personally attracted to white but I know the Mac guys will love it.;)
Usually white isn't my favorite either but when this came together it really changed my view of white as a primary color for modding.
I will be doing one in black very soon so be on the look out for that one. As I see in your profile pic you like black and blue like me. So the next one will be more our style :D
Checkout the blog page codeofficer put together http://blog.codeofficer.com/blog/201...-2-gaming-rig/.
Also the rig made the Guildwarsinsiders.com front page tonight!
If you like the build and have a reddit account I would love an up vote here.
There is a sneak peak of the black case on my fb page in my sig :)
Here is the black case that I said I would post. This one is for me :) These cases are for sale now and come with a free side panel engraving for xtremesystems members. If you would like a custom case made just for you you can contact me through PM or at my email John1253113 @ gmail.com
Empty case
http://i1156.photobucket.com/albums/...-58-16_724.jpg
Fans fitted for picture (side is not yet fitted to the case)
http://i1156.photobucket.com/albums/...-47-40_733.jpg
Just plumbed the system (in the back you can see the custom reservoir I whipped up for this)
http://i1156.photobucket.com/albums/...-16-50_780.jpg
http://i1156.photobucket.com/albums/...5-17-20_65.jpg
http://i1156.photobucket.com/albums/...-01-08_513.jpg
System specs:
Intel 2500K@4.8ghz XSPC rasa block
GTX580 with EK full cover block acetal
Laing D5 pump with g1/4 fittings.
1 EK 240 radiator
1 Swiftech 240 radiator
these are really interesting
can you share more about how the case itself is held together and the different features?
im always looking for new ways to create my acrylic cases (although i do not have CNC which would be out of my price range)
Sorry Manicdan but I can not give away too many of my secrets of how my cases are made but I can tell you about the features.
The cases have side panels that are held on by rare earth magnets when not being transported. When transported I recommend the magnets be supplemented by the screws so they don't get bumped and popped off.
The main body of the case is thermo-formed and chemically welded to hold everything together. There are not a whole bunch of screws holding it together.
The power supply on my latest revision can slide out the back allowing for easier cable management.
The hard drive holder is also removable for easier installation of drives.
Everything about the case can be customized to your specifications. I designed and built my own cnc machine to make these.
I am willing to help you produce your own design on my cnc machine for you. Pm or email me if you are interested in that.
i saw the side panel and thought you use magnets
i did that for a build back in the day and it was really cool (although i use magnets for kitchen cabinets from a local hardware store)
where did you get yours from?
as far as making it all a solid piece, do you know of a good method that works well with clear acrylic?
otherwise i might switch to black for a few panels that i would chemically weld and clear for a few others that i would stick with bolts and beams.
I got my magnets off ebay from a US seller :)
The main thing with chemically welding is the pieces have to be a tight fit without forcing. Must be withing about 1-3 thousandths accuracy to get a good bond. I do a lot of hand sanding/flattening after the piece comes off the cnc machine. Also your material must be extremely clean.
With clear acrylic you must be very careful with the solvent if it gets on stuff you don't want it you will always see the spots. Tap plastics made some decent videos on the subject on youtube.
thanks for the tips!
about how much did your cnc setup cost you?
About 5K in hardware. Then about 1000hrs of work design, fabrication, and adjustments.
hahaha, but it sure beats buying a haas for 40k dosnt it.
