Any changelog with 1707 bios ? Beta or WHQL ?
MAXIMUS V GENE BIOS 1707
1.Fixed Power On By RTC function failed.
2.Fixed F8 function is abnormal under fastboot
3.Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/c...Language=en-us
it says on asus site
Heads up for you guys the official 1707 is now up on asus site for the formula. Unable to find changelog though.
Mark
Changelog's biggest fix is:
fixed the BIOS not saving quite a few options issue ( stuck multiplier, not applying EIST enable/disable, BCLK applying, etc that started to exhibit itself since 13XX BIOSes and struck most people with 1604 BIOS )
Here are the 1707 BIOSes modded with the latest Intel RST RAID ROM ( 12.5.0.1815 )
http://www.mediafire.com/download.php?8b2j2891e75v3jp
guys
i swaped my M5F for the M5E what would be the best bios for it ?
Thanks in advance
Sergio
0021 or 0022 sergio
Thanks G for the fast reply ;)
do you have a link for it i cant seem to find it sorry
*found it :)
http://hwbot.org/forum/showthread.php?t=42040
guys i will use 3 GTX680 on the xtreme i read how to put them is there a way to use the other slot for a soundcard ? i just tried with 2 in SLI and keeps disabling one VGA :/
are you using the native or lucid red slots, the lucid slots are supposed to be better for sli so you can use lucid mode instead (but that may only be for benching) and with the lucid slots it should work fine. so just use the red slots and all should be good, but the black slot should turn off.
Im using first card on red on slot 1 second card on slot 2B wich is black and its stated on the manual that i should use it this way...then when when i put the audio card on red pcie wich is an audio card pcie x1 it disables black slot where my second vga is
So u say i put the 2 vga on the red and the audio on red and will work ?
Or i must populate all red slots to make it work ? I still dont have my third vga for tri sli
Thank u very much for ur help !
Cheers Sergio
1707 bios updates rog firmware?
OMG !!! Just flashed to BIOS 0022 and what a dif in stability and i can also disable internal VGA :D
yesss thanks mate
im dealing now with stupid INTEL RST drives that i keep getting errors in the Windows Events maybe is that the BIOS has the RAID ROM 11.0 old and im using latest drivers...i asked a friend to mod me the BIOS 0022 with that raid rom so i can test
speed of my SSD RAID went down with latest drivers...
Cheers !!!
Sergio
Guys i will be using 3 SLI im using the PSU of my sig...do i need to feed the 8pin + 4pin CPU ? im using only 8 for now ? also theres a EZ plug what connector of 6 pins is that ? its doesnt specify ? seems like a PCIe power connector
cheers !
Sergio
