Not true. Even the vinyl record master doesn't capture everything:
http://wiki.hydrogenaudio.org/index....hs_%28Vinyl%29
"The dynamic range of vinyl, when evaluated as the ratio of a peak sinusoidal amplitude to the peak noise density at that sine wave frequency, is somewhere around 80 dB. Under theoretically ideal conditions, this could perhaps improve to 120 dB. The dynamic range of CDs, when evaluated on a frequency-dependent basis and performed with proper dithering and oversampling, is somewhere around 150 dB.
Under no legitimate circumstances will the dynamic range of vinyl ever exceed the dynamic range of CD, under any frequency, given the wide performance gap and the physical limitations of vinyl playback. More discussion at Hydrogenaudio."
