Positive Displacement Vs Centrifugal Pumps - How to Select
The most obvious reason to use a PD pump is when you have a high viscosity application. It is common knowledge that a centrifugal becomes very inefficient at even modest viscosity. However, there are many other reasons to select a PD pump over a centrifugal other than high viscosity. In fact PD pumps are very commonly used on thin liquids like ammonia and solvents.
A simple rule of thumb is you should consider using a PD pump whenever you might be operating a centrifugal at other than at the BEP (Best Efficiency Point). Of course the further away from the BEP you get the more likely a PD pump will be a better choice. This can typically happen at low flow conditions, modest to high head conditions, or any type of elevated viscosity. As you can see from the efficiency curve it takes more horsepower to operate a centrifugal outside of its BEP. This horsepower has a cost, the initial cost of the larger motor plus a higher life cycle cost in energy consumed. Many times the PD pump will have a lower initial cost as well as a lower operating cost.
Another reason to use a PD pump would be if the application has variable pressure conditions. A centrifugal pump will “walk” up and down the curve which can cause process problems. A PD pump will give near constant flow that makes it possible to match the flow to the process requirements. The desire to have constant flow is the reason that a PD pump is the pump of choice for metering applications.
Obviously, if there is changing viscosity in the application the PD pump is the best choice. As can be seen from the charts, viscosity has a major impact on the centrifugals performance. Even a small change in viscosity, like 200-400 SSU, has a large impact on the centrifugal.
PD pumps generally can produce more pressure than centrifugals. This will depend on the design of each pump but pressures of 250 psi (580 feet) are not unusual for a PD pump with some models going to over 1000 psi (2,300 feet). This is a significant difference between the two principles. The capability for a PD pump to produce pressure is so great that some type of system overpressure protection is required.
Generally speaking pumps tend to shear liquids more as speed is increased and the centrifugal is a high speed pump. This makes the PD pump better able to handle shear sensitive liquids. Shear rates in PD pumps vary by design but they are generally low shear devices, especially at low speeds. Internal gear pumps, for example, have been used to pump very shear sensitive liquids. It is important to contact the manufacturer for specific information on shear rates and application recommendations.
By their nature, PD pumps create a vacuum on the suction side so they are capable of creating a suction lift. The standard ANSI centrifugal does not create a vacuum so it can not lift liquid into the suction port. There are self-priming centrifugal designs that can lift liquid an average of 15 feet. This corresponds to a vacuum of 13” hg. Wetted PD pumps (a pump that is not full of liquid but with some liquid in it) can often reach vacuums of 25 to 28” hg. So a PD pump is the logical choice when there is a suction lift required.
As mentioned earlier, PD pumps tend to run at lower speeds than centrifugals. This will have an impact on seal life, so PD seals tend to last longer than seals in centrifugal pumps. In addition, to assure adequate seal life a centrifugal will typically require one of the seal flush plans. A PD pump, because of its lower shaft speed typically does not need an external flush plan. Also, generally speaking, low speed mechanical devices tend to operate longer than high speed mechanical devices.
At certain combinations of flow and pressure centrifugals are inherently inefficient, due to the design of the impeller and the short radius turn the flow must make. These applications are generally under 100 GPM but particularly under 50 GPM. A PD pump, by contrast, is very well suited for low flow conditions. Centrifugals, by contrast, tend to do very well in high flow conditions.
source
PD pumps wiki
Did anyone try PD pumps before?
