Hey Luke. its time you watched your language. I'll ask Ron or someone to come in here and sort this out.
sorry, but how I should react on such a bs...
His posts were already removed once.
Put's on mod hat;
Gentlemen;
I think it's time some of you took a little vacation from XS so that you can think about your writing style.
That's the warning.
Post anything in this thread thats not constructive and your gone till 2009 minimum.
Capice?
Thanks for reading.
how did u make the mapp bottles into oil seps?
You drill two holes in the side and one in the bottom. The bottom hole is used for the separated oil, the lower hole in the side is used as the inlet, and the higher hole is used for the gaseous outlet. I personally would use the hole for the valve on the top as the gaseous outlet and drill out the valve so you don't have that leaking under pressure and low temperatures.
thanks:D
Sorry Luke, but this thread is going to Customer/Builder relations so we can control who post in it.
If you flame, you will get banned. ;)
And if Ron misses any i'll grab them!:D
let's keep it clean and friendly
Please notice guys, that those are phase separators :-)
So bottom hole is used for the oil AND gas in liquid state, top hole is for high pressure has, which isn`t liquid yet, so we can get them separated in simple way. Not 100% of course.
symphy, for what temperature we should aim at this time ? I`m not overclocker and don`t know todays cpu`s, what do you wanna from that unit.
edit:
Cascade got second condenser :)
gotta camera :cool:
Cheers to Marvin :clap: :up:
Now cheers to local corner shop to supply luke with couple of batteries ;) Looking forward to see progress! :up:
Greets,
N.
Gotta photos :-) (sorry for mess in celar)
Big thanks to Marvin, you know I luv ya my friend :D
http://www.teampuss.com/lukexe/3_stage_new/SSA40012.jpg
Concept with two condensers (one for 1st stage, second for 3rd stage).
http://www.teampuss.com/lukexe/3_stage_new/SSA40017.jpg
http://www.teampuss.com/lukexe/3_stage_new/SSA40018.jpg
http://www.teampuss.com/lukexe/3_stage_new/SSA40019.jpg
http://www.teampuss.com/lukexe/3_stage_new/SSA40031.jpg
http://www.teampuss.com/lukexe/3_stage_new/SSA40046.jpg
Some frost.
http://www.teampuss.com/lukexe/3_stage_new/SSA40058.jpg
+0,5bar (7psi) suction pressure @ -76C (manometer is domaged and shows always +1 :p)
http://www.teampuss.com/lukexe/3_stage_new/SSA40020.jpg
two way cut-off switches
http://www.teampuss.com/lukexe/3_stage_new/SSA40022.jpg
manometers
http://www.teampuss.com/lukexe/3_stage_new/SSA40028.jpg
Fan for extra condenser
http://www.teampuss.com/lukexe/3_stage_new/SSA40032.jpg
http://www.teampuss.com/lukexe/3_stage_new/SSA40033.jpg
New 3,7kg bottle of ethylene :)
http://www.teampuss.com/lukexe/3_stage_new/SSA40062.jpg
and some sub-zero temps @ 1st stage.
That`s all for now.
Looking good Luke, keep on working!
P.S.: Is that condensor on third stage being used as R14/R50 desuperheater?
Greets,
N.
Yeap
I tried already. That`s the best I can get
I'm guessing you blew out the gauge then running a high static. I had that happen once on a gauge, was pressure testing to 350PSI and the low-side gauge was permanently damaged.
Looks great man. So lemme see if i have this straight, the first stage is an triple autoc? Where would the second condensor that you're using as a desuperheater go? Right in next to the other condensor? Sorry, I'm fairly new to phase (but will have firsthand experience starting tomorrow;))
Good luck,
Eli
Hello
Yeap, first stage is triple-autocascade (let`s say, pseudo, because now it`s autocascading a bit, should be there -90 at least)
The second condenser will be just after oil separator on third stage (wanna have around 20*C on condenser exit, less load for other stages).
@ [XC] gomeler
Yeap, I got too big static for that gauge :)
Gotta arranged final parts place, I resigned two-condensers idea.
Choosed two powerfull compressors for II and III stages. Assembled everything. Gotta buy captube, few meters of 6mm pipe, insulation and oxygen for torch and it will be done.
gotta question about dual captube feed. How I can use it ? It`s idea for big load ?
Dual captube works fine if you don't have a wide enough bore single capillary tube. I used two 2.6 meter 0.7mm bore capillary tubes b/c I didn't have any larger capillary tubing. This was with a 7/8hp compressor and a slightly undersized condenser. Held the 2nd stage just fine(3/4hp compressor) but I would have sized it to around 2.8 to 2.9 meters to reduce capacity slightly in my build as the HX could have been colder. Just play with it, start with a longer length than you think you'll need and trim it down as you go.
