Maybe Sandforce controllers work better with properly written FW. :shrug: :up:
1000Tb of host writes seems a lot!
I wonder if the Corsair Force GT 240Gb can handle that kind of a write endurance?
Intel 330 120GB
634.53TB Host writes
2.30TiB Host reads
Reallocated sectors : 05 43 +8
Available Reserved Space : E8 100
MWI 26
[B5] 21
[B6] 22
[F1] Total LBAs Written 20792174
[F2] Total LBAs Read 75341
[F9] Total NAND Writes 458046GB // ~447TiB
POH 1530
MD5 OK
125.21MiB/s on avg (~74 hours)
Kingston SSDNow 40GB (X25-V)
1150.59TB Host writes (37702684*32)
Reallocated sectors : 05 67
Available Reserved Space : E8 98
POH 10266
MD5 OK
33.70MiB/s on avg (~74 hours)
Samsung 830 256GB Day 128
(GiB) 3,159,768
(TiB) 3,085
(PiB) 3.03
(Avg) 298.40 MB/s
(B1) Wear Leveling Count: 13,686
(B6) Erase Fail Count: 9
(05) Reallocated Sectors: 36864
(POH) 3130
Bah, my vertex 4 is still not performing right.
Will decide whether to just kill it as is, or just keep it for something else.
Yeah, a 1.3.bugfixed firmware would have been good ... but I think the vertex 4 is solely focused on write benchmarks at all costs. It kinda has tunnel vision to other ssd requirements.
The plextor/liteon drives are a much better buy at the moment for performance.
I still have an unopened Vertex Turbo 64GB laying around somewhere, maybe the third time is the charm?
...Probably not.
Intel 330 120GB
641.41TB Host writes
2.32TiB Host reads
MWI 25
[B5] 21
[B6] 22
[F1] Total LBAs Written 21017815
[F2] Total LBAs Read 75912
[F9] Total NAND Writes 463017GB // ~452TiB
POH 1546
MD5 OK
125.50MiB/s on avg (~11 hours)
1152.56TB Host writes (37767241*32)
POH 10282
MD5 OK
36.89MiB/s on avg (~11 hours)
I needed the SATA ports last night so both drives had a 10 minute break. (gave them a cleaning as well by triggering TRIM)
Attachment 128870
I've changed the filling for the drives that are paused.
Based on current figures this might be the outcome at MWI 0
Attachment 128871
We used a Vertex 3 MaxIOPS 240GB at work for a critical server.
We had write errors from Oracle, so we switched the SSD. We discovered that the SSD, even with a almost perfect SMART data (2TB write, 200TB read, maximum difference between most worn cell and best cell = 1), it was impossible to copy a 8GB file entirely, it blocks when there is 760MB left. All the other data was intact.
How can this be possible? Isn't the controller supposed to mark bad blocks and not use them? Or is it because the SSD doesn't have idle time?
Yesterday I upgraded the firmware to 2.22. It was 2.15 since installed.
We are really not a support service for OCZ, especially since I'm here to kill OCZ drives, but there seems to be something ether wrong with your SSDs or server. I've never seen such a situation on SSDs here, and I've copied some whopper 20gig files to and from them.
Kensiko...this thread is dedicated to endurance testing, maybe you should post in the hardware-storage section.
Here are todays update:
m4
1295.2153 TiB
5392 hours
Avg speed 74.43 MiB/s.
AD 133 to 126
P/E 22267.
C3 4457
CE 58
MD5 OK.
Reallocated sectors : 00
http://www.diskusjon.no/index.php?ap...tach_id=498606
Intel X25-M G1 80GB
825.25 TiB
24679 hours
Reallocated sectors : 226 to 255 to 17
Available Reserved space: 40 to 37
MWI= 128 to 111
MD5 =OK
30.75 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498607
Intel X25-E 64GB
594.85 TiB
1860-30=1830 hours
Available Reserved space: 99
MWI= 96
MD5 =OK
91.32 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498605
Mtron Pro 7025 32GB
Paused until new firmware is updated.
Samsung 830 256GB Day 129
(GiB) 3,197,663
(TiB) 3,122
(PiB) 3.07
(Avg) 298.46 MB/s
(B1) Wear Leveling Count: 13,849
(POH) 3177
4PB, here I come. It's odd that it's been almost 1.5PB without an erase failure, but hey, I'll take it.
Intel 330 120GB
651.40TB Host writes
2.34TiB Host reads
Reallocated sectors : 05 45 +2
MWI 24
[B5] 22
[B6] 23
[F1] Total LBAs Written 21345238
[F2] Total LBAs Read 76706
[F9] Total NAND Writes 470230GB // ~459TiB
POH 1569
MD5 OK
125.28MiB/s on avg (~35 hours)
1155.21TB Host writes (37854060*32)
POH 10305
MD5 OK
34.38MiB/s on avg (~35 hours)
Sandisk Extreme G25 - 120gb - Day 54
Drive hours: 1291
ASU GiB written: 558,052.55 GiB (544.97 TiB)
Avg MB/s: 125.86 MB/s (69.64 hours)
MD5: OK
Host GB written (F1): 562,193 GiB (549.02 TiB)
NAND writes (E9): 419,639 GiB (409.80 TiB)
Retired Block Count (05): 4 raw
Failure count (AB, AC): 1 program, 1 erase
Raw Error Rate (01): 100 normalized
Media Wearout Indicator (E7): 10 normalized
Wear Range Delta (B1): 4 raw
Reported Uncorrectable Errors (BB): 0 raw
Vertex 4 - 50% OP - 128gb - PAUSED
Drive hours: 214
ASU GiB written: 96,525.65 GiB (94.26 TiB)
Avg MB/s: 0 MB/s (0 hours)
MD5: OK
Host GB written (E8): 97,836.11 GiB (95.54 TiB, 205177187947 raw)
Raw Read Error Rate (01): 5 raw
Reallocated Block Count (05): 0 raw
Remaining Life (E9): 77 normalised
I decided to let the V4 go for a while, but the loop started degrading to sub 100meg per sec speeds (after the initial burst of performance)
Drive just doesn't want to do what I want it to do.
m4
1301.0084 TiB
5415 hours
Avg speed 74.71 MiB/s.
AD 126 to 123
P/E 22365.
C3 4457
CE 58
MD5 OK.
http://www.diskusjon.no/index.php?ap...tach_id=498690
Intel X25-M G1 80GB
827.79 TiB
24702 hours
Reallocated sectors : 17 to 42
Available Reserved space: 37 to 35
MWI= 111 to 104
MD5 =OK
29.87 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498691
Intel X25-E 64GB
602.03 TiB
1883-30=1853 hours
MWI= 96
MD5 =OK
92.44 MiB/s on avg
http://www.diskusjon.no/index.php?ap...tach_id=498689
Mtron Pro 7025 32GB
I'm going for 3 weeks on vacation so my updates can be kind of sporadic. I've installed a ups to prevent a shutdown from powerfailures and will be crossing my fingers :)
I think that the G1 might soon die on me. It droppes reserve space at 1-2% every day, just hope it stays in there until I'm back again.
B.A.T. -- I don't know about you, but my drives only like to die when I'm out of town. I'd say it's a guarantee that something will die while you're gone. That's just how it works.
I'll just have to wait and see :D
Intel 330 120GB
661.85TB Host writes
2.37TiB Host reads
Reallocated sectors : 05 52 +7
MWI 22
[B5] 25
[B6] 27
[F1] Total LBAs Written 21687618
[F2] Total LBAs Read 77614
[F9] Total NAND Writes 477773GB // ~466TiB
POH 1593
MD5 OK
125.31MiB/s on avg (~59 hours)
1157.99TB Host writes (37945037*32)
POH 10329
MD5 OK
33.89MiB/s on avg (~59 hours)
Attachment 128910
Intel 330 120GB
672.40TB Host writes
2.39TiB Host reads
Reallocated sectors : 05 60 +8
MWI 21
[B5] 29
[B6] 31
[F1] Total LBAs Written 22033283
[F2] Total LBAs Read 78465
[F9] Total NAND Writes 485387GB // ~474TiB
POH 1617
MD5 OK
125.41MiB/s on avg (~83 hours)
1160.78TB Host writes (38036572*32)
Reallocated sectors : 05 68 +1
POH 10354
MD5 OK
33.69MiB/s on avg (~83 hours)
Sandisk Extreme G25 - 120gb - Day 56
Drive hours: 1343
ASU GiB written: 580,836.71 GiB (567.227 TiB)
Avg MB/s: 125.13 MB/s (121.85 hours)
MD5: OK
Host GB written (F1): 585,091 GiB (571.38 TiB)
NAND writes (E9): 436,741 GiB (426.50 TiB)
Raw Error Rate (01): 116 normalized
I gave both drivers a cleaning (trim) last night, doesn't look like it helped.
Intel 330 120GB
682.46TB Host writes
2.42TiB Host reads
Reallocated sectors : 05 74 14
MWI 20
[B5] 36
[B6] 38
[F1] Total LBAs Written 22362756
[F2] Total LBAs Read 79261
[F9] Total NAND Writes 492645GB // ~481TiB
POH 1640
MD5 OK
125.22MiB/s on avg (~12 hours)
1163.53TB Host writes (38126614*32)
POH 10377
MD5 OK
35.29MiB/s on avg (~12 hours)
