AX1200 welded its PCIe connectors in
A few days ago, my machine was sitting idling at the windows desktop while I was downstairs when I smelled a burning smell, went upstairs and found the PC off and the room full of smoke.
Not a great experience, as you can imagine.
The system is a 2600k on a Maximus IV Extreme with SLI 580s etc. The PSU is a Corsair AX1200 which I brought at the same time as getting all the other parts of the system about a year and a half ago.
After the smoke incident, I took the motherboard and CPU out and took them to a local PC shop to get them to test, and they found the CPU OK but the motherboard (Asus Maximus IV extreme) was dead. Thinking that was the only problem, I ordered an identical replacement motherboard, and stripped the system down today to fit it.
While I was at it, I figured I'd best test the PSU outputs to ensure I wasn't about to damage the new motherboard, so I looked up some pinouts, broke out my multimeter, bridged the pins to fire the PSU up and tested away.
Everything looked OK at first, 24-pin ATX checks out with normal voltages, same for the molex power connections, then I tested the PCIe 6+2 connectors. One pair were fine, with 3 pairs of +12v/GND and GND/GND on the 2-pin part. The second set had +12v on 2 pairs, on each, but one pair on each were wierd - like +3.5v and +4v or thereabouts.
I immediately raised an RMA with Corsair before even removing the PSU, but now I have removed it I'm not suprised there was a lot of smoke - the PCIe connectors at the PSU end of the modular cables on the 2 faulty outputs have basically welded themselves into the PSU and cannot be removed. Sniffing around the socket, there is still a very strong smell even days later like the one at the time of the incident.
I have inspected my graphics cards very closely (GTX580s) and both look fine - no popped or bubbled chips, no swollen capacitors, no charring or burned bits, no smell of burning.
I wonder if anyone has any input on how safe it's going to be to test my graphics cards on my new motherboard when a replacement PSU arrives. I am concerned that I might plug everything back in and kill another motherboard, possibly kill another graphics card or whatever. I don't even know now which graphics card was plugged into the cables that have melted, as they have been out of the system sitting around since I first took the mobo and cpu out for testing.
I literally have no idea now if the entire system could be fried. I have SSDs in RAID, multiple HDDs, sound and RAID cards and of course the 580s, I just hope this hasn't bricked them all.
So, how do I proceed in terms of testing stuff to ensure I don't do any further damage when putting this all back together?
Also, does anyone know if Corsair will pay for replacements if their PSU has destroyed my system?
