same problem here, in SATA 1,2,3,4 disk not working correctly... usable are only 5 a6 SATA port, weird
Fugger - yeah, uSB OS install is horror, but i have OC panel, CD and sound card ...
Nothing but the board and disk here, :(, as far as pure ocing is concerned, this seems to be doing its job pretty well but for 24/7 use, it certainly needs a few BIOS updates
new bios ... 121
http://rapidshare.com/files/40133329...1_rar.zip.html
i have a serius dubt about the stability of tath mobo......
watt output problem
usb speed
sata bug
qpi bug 980x
why msi? why?
Do you have the board Andrea ? Works flatout here with GT over 6Ghz, dunno what the Watt problem is... I Hope Raju get's it out in the open so we can relay it to MSI too , maybe to force them to change it in a new rev...
QPI problem exists also with my UD9 sample,so a bios could be the fix... Did USB3 tests nothing slow there... will have to check the other ports...
The input inductor "problem" I stated was for the sample boards only - it has been fixed in retail. It's not good to have an OCP limit set past the maximum value of the input inductor. The other "problem", I have relayed back to MSI and it could be a number of things that add up to it manifesting. It won't affect outright CPU MHz in most instances - but will affect stability in certain scenarios depending upon what you're looking for the board to do.
Later
Raja
Official MSI 1.2 BIOS
http://download1.msi.com/files/downl...xe/7666v12.zip
board seems pretty stable under LN2, but i think it must be damned ... :) Few days of benching, and 2 (yeah two) 980X are dead and one Corsair GT kit too, no extreme voltages, no extreme benching ... will see how many components will survive MOA 2010...
Keep the updates coming guys.
I really want to get a new x58 board and this one looks good - just wanted to give a non-Asus board a chance for a change...
Doubt:
MSI XPower or Gigabyte X58A-UD7?
Analyzing greater stability, features and technology. What would be better between the two? Both motherboards are the same price. Thanks!
As of now for sure RE3, but I am sure once the bugs are fixed on the XPower its gonna be a pretty good motherboard for Extreme Overclocking at a very cheap price(infact it still is, since once you figure out the minor bugs, they dont bug you during extreme overclocking, :P)
i honestly dont care for the price
if the xpower was good i woulda paid more for it
i'm not gonna wait 6 months for fixes
they have been fixin the board for months now n still:down:
on paper the xpower is great but :rofl: i got no faith in msi for bios fixes
if they do fix it one day i'll buy 1 but look like a few months off maybe a newer rev
Excelent MB, much better than my oldie Classified 760.
First run, no tweaks.
http://www.unknownteam.cl/wp-content...0/07/28236.jpg
1 x SSD Corsair xtreme 64GB
1x 160gb Seagate Sata
1x 250gb W.Digital Sata
1x 500gb Seagate Sata 7200.12
1x 80GB W.Digital Sata
Im having lots of issues with this new board.. this is my second cause the other failed... Everytime I do over 5.4 on GT it gives me memory errors... this has the ocp mod at 40k.. even lowered to 30k... My 760 classy is a way better board then this....
bugged divider ? We had no issues here with GT over 6Ghz, rams 1000MhzC7 and 4600 uncore speeds...
You need to explain more and show us screenshots etc to get help...
Is this a problem all across the line or just board per board?
