whats your temps ith this settings?
Cpu temps go to 68c Core temps reach 55c
Still a bit high for my liking and nothing to do about it now :shakes: I wonder if i get H100 with 4 Push/pull fans would it be any better?
55C in Coretemp is OK for FX...My FX running OK up to 68 C in Coretemp (so about 80-85 C in real). IS not so sensitive at temps as Phenom II
I see. So what is the Maximum safe temps? and are you running @ these temps for a 24/7 setup?
no, only in PRIME...I think, about 60-65C in Coretemp will be OK for highest settings clocks/voltage
My temp readings are from Prime95 as well. I'm going to Order a Noctua Nh-D14 soon and put it in my system. It should cool it down by 5-6c less i think.
I will have two faildozers here Friday to test, hopefully something nice to contribute to this thread:up:
to time Im at 460x MHz/2608 MHz NB 1.44V, temps are still good :)
Have a 1211 PGN I am testing now
lol, u have the same batch as me :)...(Im testing too, FX in my signature is different chip)
Update info to my 1210PGN 1.535V and 4850 MHz stable...So, it is worse than my old FX. CPU-NB is over 2600 MHz. But power consumption is about 70W lower!
FlanK3r...|second AMD FX-8150.......|1210PGN (VID 1.3125V)......|0057.....|4850 MHz @ 1.535V.................|AMD Asetek liquid cooler......|5066 MHz @ 1.556V (high temps)
two 1210PGN's just showed up still waiting for a board that a friend is bringing over to test IMC.
Where is the VID
Code:CPU-Z TXT Report
Binaries
CPU-Z version 1.60.1
Processors
Number of processors 1
Number of threads 8
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
-- Core 4
-- Thread 0 4
-- Core 5
-- Thread 0 5
-- Core 6
-- Thread 0 6
-- Core 7
-- Thread 0 7
Processors Information
Processor 1 ID = 0
Number of cores 8 (max 8)
Number of threads 8 (max 8)
Name AMD FX-8150
Codename Zambezi
Specification AMD FX(tm)-8150 Eight-Core Processor
Package Socket AM3+ (942)
CPUID F.1.2
Extended CPUID 15.1
Core Stepping OR-B2
Technology 32 nm
TDP Limit 124 Watts
Core Speed 4615.8 MHz
Multiplier x FSB 23.0 x 200.7 MHz
Stock frequency 4600 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP
L1 Data cache 8 x 16 KBytes, 4-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size
L3 cache 8 MBytes, 64-way set associative, 64-byte line size
FID/VID Control yes
Min FID 7.0x
# of P-States 7
P-State FID 0x1A - VID 0x0B - IDD 18 (21.00x - 1.412 V)
P-State FID 0x17 - VID 0x0C - IDD 18 (19.50x - 1.400 V)
P-State FID 0x1E - VID 0x17 - IDD 12 (23.00x - 1.262 V)
P-State FID 0x11 - VID 0x1C - IDD 11 (16.50x - 1.200 V)
P-State FID 0xB - VID 0x25 - IDD 8 (13.50x - 1.087 V)
P-State FID 0x5 - VID 0x30 - IDD 7 (10.50x - 0.950 V)
P-State FID 0x10C - VID 0x38 - IDD 5 (7.00x - 0.850 V)
PStateReg 0x800001B5-0x0000161A
PStateReg 0x800001B5-0x00001817
PStateReg 0x80000176-0x00002E1E
PStateReg 0x8000016A-0x00003811
PStateReg 0x80000153-0x00004A0B
PStateReg 0x80000141-0x00006005
PStateReg 0x8000012D-0x0000704C
PStateReg 0x00000000-0x00000000
Package Type 0x1
Model 00
String 1 0x0
String 2 0x0
Page 0x0
CmpCap 7
Base TDP 14 Watts
Boosted P-States 2
Max non-turbo ratio 23.00x
Max turbo ratio 21.00x
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Attached device PCI device at bus 0, device 24, function 5
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02020001h
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Eh
Cache descriptor Level 1, D, 16 KB, 1 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Cache descriptor Level 3, U, 8 MB, 8 thread(s)
CPUID
0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00600F12 0x00080800 0x1E98220B 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x00000006 0x00000000 0x00000000 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000
0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00600F12 0x10000000 0x01C9BFFF 0x2FD3FBFF
0x80000002 0x20444D41 0x74285846 0x382D296D 0x20303531
0x80000003 0x68676945 0x6F432D74 0x50206572 0x65636F72
0x80000004 0x726F7373 0x20202020 0x20202020 0x00202020
0x80000005 0xFF20FF18 0xFF20FF30 0x10040140 0x40020140
0x80000006 0x64000000 0x64004200 0x08008140 0x0040C140
0x80000007 0x00000000 0x00000000 0x00000000 0x000003D9
0x80000008 0x00003030 0x00000000 0x00004007 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00010000 0x00000000 0x000014FF
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF020F018 0x64000000 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000
0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F
0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000
0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000
0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001
0x8000001D 0x0001C163 0x0FC0003F 0x000007FF 0x00000001
0x8000001E 0x00000010 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000018
MSR 0xC0010061 0x00000000 0x00000040
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010064 0x800001B5 0x0000161A
MSR 0xC0010065 0x800001B5 0x00001817
MSR 0xC0010066 0x80000176 0x00002E1E
MSR 0xC0010067 0x8000016A 0x00003811
MSR 0xC0010068 0x80000153 0x00004A0B
MSR 0xC0010015 0x00000000 0x01000011
MSR 0xC001001F 0x00404000 0x00810008
MSR 0xC0010058 0x00000000 0xE0000021
MSR 0xC0010004 0x00000000 0xEC5671A5
MSR 0xC0010071 0x02800006 0x3C022E1E
MSR 0xC0010070 0x00000000 0x1E022E1E
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 02020001h
CPUID
0x00000001 0x00600F12 0x01080800 0x1E98220B 0x178BFBFF
0x8000001E 0x00000011 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0xC0010004 0x00000000 0xEB9647C7
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 02020001h
CPUID
0x00000001 0x00600F12 0x02080800 0x1E98220B 0x178BFBFF
0x8000001E 0x00000012 0x00000101 0x00000000 0x00000000
MSR 0xC0010004 0x00000000 0xECBB5E60
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 02020001h
CPUID
0x00000001 0x00600F12 0x03080800 0x1E98220B 0x178BFBFF
0x8000001E 0x00000013 0x00000101 0x00000000 0x00000000
MSR 0xC0010004 0x00000000 0xEBFBC083
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 4, Thread ID 0
Type 02020001h
CPUID
0x00000001 0x00600F12 0x04080800 0x1E98220B 0x178BFBFF
0x8000001E 0x00000014 0x00000102 0x00000000 0x00000000
MSR 0xC0010004 0x00000000 0xF5474995
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 5, Thread ID 0
Type 02020001h
CPUID
0x00000001 0x00600F12 0x05080800 0x1E98220B 0x178BFBFF
0x8000001E 0x00000015 0x00000102 0x00000000 0x00000000
MSR 0xC0010004 0x00000000 0xECC2D41B
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 6, Thread ID 0
Type 02020001h
CPUID
0x00000001 0x00600F12 0x06080800 0x1E98220B 0x178BFBFF
0x8000001E 0x00000016 0x00000103 0x00000000 0x00000000
MSR 0xC0010004 0x00000000 0xECC66116
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 7, Thread ID 0
Type 02020001h
CPUID
0x00000001 0x00600F12 0x07080800 0x1E98220B 0x178BFBFF
0x8000001E 0x00000017 0x00000103 0x00000000 0x00000000
MSR 0xC0010004 0x00000000 0xEC87A581
Chipset
Northbridge AMD RD9x0 rev. 02
Southbridge AMD SB910/950 rev. 40
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 16384 MBytes
Channels Dual
Memory Frequency 936.5 MHz (3:14)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 11
RAS# Precharge (tRP) 11
Cycle Time (tRAS) 24
Bank Cycle Time (tRC) 46
Uncore Frequency 2207.6 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) G.Skill (7F7F7F7FCD000000)
Size 8192 MBytes
Max bandwidth PC3-10700 (667 MHz)
Part number F3-2133C9-8GBXH
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.3
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 5.0-5-5-14-19 @ 380 MHz
JEDEC #2 6.0-6-6-17-23 @ 457 MHz
JEDEC #3 7.0-7-7-20-27 @ 533 MHz
JEDEC #4 8.0-8-8-22-30 @ 609 MHz
JEDEC #5 9.0-9-9-25-34 @ 685 MHz
JEDEC #6 10.0-10-10-28-38 @ 761 MHz
XMP profile XMP-2000
Specification PC3-16000
Voltage level 1.600 Volts
Min Cycle time 1.000 ns (1000 MHz)
Min tRP 9.88 ns
Min tRCD 9.88 ns
Min tWR 15.00 ns
Min tRAS 28.63 ns
Min tRC 38.88 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 9.0-12-12-33-44-2T @ 1125 MHz (1.600 Volts)
XMP profile XMP-1778
Specification PC3-14200
Min Cycle time 1.125 ns (889 MHz)
Min tRP 12.00 ns
Min tRCD 12.00 ns
Min tWR 18.00 ns
Min tRAS 34.50 ns
Min tRC 46.88 ns
Min tRFC 312.50 ns
Min tRTP 9.00 ns
Min tRRD 7.13 ns
Command Rate 2T
XMP #1 9.0-12-12-32-44-2T @ 923 MHz (1.600 Volts)
DIMM # 2
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Size 8192 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.3
Min tRP 9.88 ns
Min tRCD 9.88 ns
Min tWR 15.00 ns
Min tRAS 28.63 ns
Min tRC 38.88 ns
Min tRFC 260.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
Command Rate 2T
Min tRP 12.00 ns
Min tRCD 12.00 ns
Min tWR 18.00 ns
Min tRAS 34.50 ns
Min tRC 46.88 ns
Min tRFC 312.50 ns
Min tRTP 9.00 ns
Min tRRD 7.13 ns
Command Rate 2T
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 11 0B 02 04 21 00 09 03 11 01 08 0C 00 7E 00
10 69 78 69 30 69 11 20 89 20 08 3C 3C 00 F0 83 05
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 21 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 A9 E1
80 46 33 2D 32 31 33 33 43 39 2D 38 47 42 58 48 00
90 00 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0C 4A 3F 13 01 08 0A 60 11 2C 08 40 20 00 34 4F
C0 4F 78 10 E5 37 3F 00 20 08 3C 30 00 C8 3C 00 00
D0 10 00 00 C1 C6 C6 C6 98 00 00 00 00 2C 09 4E 20
E0 00 3F 60 60 90 11 14 77 4B 00 C4 09 48 39 00 F0
F0 48 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00
DIMM # 2
SPD registers
Monitoring
Mainboard Model Crosshair V Formula (0x0000071A - 0x187EC7E1)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8721
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8721
LPCIO Revision ID 0x1
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 21 01 00 00 00 99 09 C0 00 00 00 9F 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 02 30 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0290
Hardware Monitors
Hardware monitor ITE IT8721
Voltage 0 11.73 Volts [0xEB] (+12V)
Voltage 1 4.85 Volts [0xE7] (+5V)
Voltage 2 1.43 Volts [0x77] (CPU VCORE)
Voltage 3 1.64 Volts [0x89] (VIN3)
Voltage 4 0.80 Volts [0x43] (VIN4)
Voltage 5 3.15 Volts [0xD2] (+3.3V)
Voltage 6 0.44 Volts [0x25] (VIN6)
Voltage 7 0.40 Volts [0x21] (VIN7)
Voltage 8 1.72 Volts [0x8F] (VIN8)
Temperature 0 64°C (147°F) [0x40] (CPU)
Temperature 1 30°C (86°F) [0x1E] (Mainboard)
Fan 0 1421 RPM [0x1DB] (CPU)
Fan 1 1369 RPM [0x1ED] (FANIN1)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 19 00 7B 02 00 00 00 00 00 80 58 0F 03 D9 ED 00
10 A9 71 42 37 C7 00 00 00 01 01 00 F0 80 08 08 08
20 EB E7 77 8A 43 D2 25 21 8F 40 1E 80 80 03 23 23
30 A9 30 81 A1 E8 5A E7 F2 7D 75 2C 9A AC 64 9A 0E
40 6E FA 82 26 A8 D7 5F 40 AD 6A D4 00 FF FF FF FF
50 2F 18 7F 7F 7F 40 00 00 90 00 3A 12 60 00 00 00
60 80 00 7F FF 00 41 00 FF 80 00 7F FF 00 41 00 FF
70 80 00 7F FF 00 41 00 FF FF FF FF FF FF FF FF FF
80 00 00 00 00 00 00 00 00 00 00 00 00 00 97 02 C7
90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
A0 5E A4 A4 A4 A4 A4 A4 FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor Asus IROG 02
Temperature 0 36°C (96°F) [0x24] (SB)
Temperature 1 62°C (143°F) [0x3E] (NB)
Fan 1 1734 RPM [0x6C6] (Fan #2)
Register space SMBus, base address = 0x0B00
SMBus request channel 0x0, address 0x40
00 FF FF FF FF FF FF FF 00 00 00 FF FF FF FF FF FF
10 5A 5A 5A 5A 5A 5A 5A FF FF FF FF FF FF FF FF FF
20 FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 00 00 00 97 FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 FF FF FF FF FF FF FF FF FF FF 86 C4 03 00 66 EC
90 00 00 C8 06 00 00 00 00 FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 35 24 3E 1F A8 A8 A8 FF FF FF FF FF FF 00 50 00
Hardware monitor Asus IROG 01
Voltage 0 1.43 Volts [0x595] (CPU)
Voltage 1 1.21 Volts [0x4BA] (CPU/NB)
Voltage 2 1.11 Volts [0x457] (ICH Core (NB))
Voltage 3 2.53 Volts [0x9DF] (CPU VDDA)
Voltage 4 1.62 Volts [0x655] (DRAM)
Voltage 5 1.21 Volts [0x4BA] (HT)
Voltage 6 1.11 Volts [0x451] (IOH Core (SB))
Fan 0 1384 RPM [0x568] (PSU)
Fan 1 1429 RPM [0x595] (CPU)
SMBus request channel 0x0, address 0x43
00 FF 88 54 5B 54 C0 00 00 FF FF FF 00 00 00 FF FF
10 00 18 01 88 FF FF FF FF FF F8 FF 88 FF FF FF 00
20 FF FF FF FF FF FF FF 00 00 00 00 00 FF 00 00 00
30 00 BC 00 FF C8 00 51 00 00 E4 00 FF FF FF 00 00
40 FF FF FF FF FF FF FF 00 01 FF FF FF 00 FF FF FF
50 2E 46 08 00 00 FF FF FF FF FF FF 00 FF 00 FF FF
60 90 01 B0 00 00 04 FF FF 01 FF FF FF FF FF FF FF
70 04 FF FF FF FF FF 01 01 FF 00 09 FF FF 64 00 FF
80 FF FF FF FF FF FF FF FF FF FF DD 1F 12 00 21 12
90 8E 05 CE 04 5E 04 DF 09 55 06 BA 04 51 04 00 00
A0 69 05 9A 05 00 00 00 00 FF FF FF FF 45 FF FF FF
B0 FF 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF
Hardware monitor AMD ADL
Voltage 0 1.10 Volts [0x44C] (VIN0)
Temperature 0 45°C (113°F) [0x2D] (TMPIN0)
PCI Devices
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A14
Revision ID 0x02
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1002
Subsystem ID 0x5A14
Int. Line 0xFF
Int. Pin 0x00
PCI capability
Caps class HyperTransport
Caps offset 0xF0
Interface type MSI Mapping
PCI capability
Caps offset 0xC4
Caps revision 3.00
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 2200 MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200 MHz
PCI capability
Caps offset 0x40
Interface type Retry Mode
PCI capability
Caps offset 0x54
Interface type Clumping
PCI capability
Caps offset 0x9C
Interface type Gen3
PCI capability
Caps class Message Signalled Interrupts
Caps offset 0x70
PCI registers
00 02 10 14 5A 02 00 10 20 02 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 14 5A
30 00 00 00 00 F0 00 00 00 00 00 00 00 FF 00 00 00
40 08 54 00 C0 C1 00 00 00 00 00 00 00 42 20 05 00
50 02 10 14 5A 08 9C 00 90 08 10 00 00 00 00 00 00
60 3C 00 00 00 00 00 00 00 00 00 00 40 64 50 00 78
70 05 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 10 00 00 03 20 02 30 00 31 20 00 00
90 00 00 00 D0 00 00 00 00 10 08 00 00 08 70 3C D0
A0 66 00 00 00 00 00 00 86 00 00 00 00 79 41 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 80 08 40 80 02 20 80 11 11 D0 00 00 00
D0 60 0C F5 7F 13 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 05 00 FF FF FF FF 00 00 00 00 00 00 00 00
F0 08 C4 03 A8 00 80 80 00 01 00 00 00 08 00 C2 FE
Description PCI to PCI Bridge
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A16
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x34
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0x50
Caps version 1.2
PCI capability
Caps class PCI Express
Caps offset 0x58
Device type Root Port of PCI-E Root Complex
Port 0
Version 2.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
PCI capability
Caps offset 0xA0
PCI capability
Caps class Subsystem Vendor
Caps offset 0xB0
SubVendor ID 0x1002
SubSystem ID 0x5A14
PCI capability
Caps offset 0xB8
Extended capabilities
Caps class Vendor Specific
Caps offset 0x100
Vendor ID 1
Size 16
Caps class 0xD
Caps offset 0x190
PCI registers
00 02 10 16 5A 07 00 10 00 00 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 E1 E1 00 20
20 A0 FE A0 FE 01 D0 F1 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 34 01 18 00
50 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00
60 00 08 00 00 02 CD 31 00 40 00 02 F1 80 25 14 00
70 00 00 48 01 00 00 01 00 00 00 00 00 3F 00 00 00
80 06 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 05 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 0D B8 00 00 02 10 14 5A 08 00 03 A8 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 0B 00 01 19 01 00 01 01 00 58 22 00 00 00 00 00
110 02 00 01 19 00 00 00 00 00 00 00 00 00 00 00 00
120 01 00 00 00 FF 00 00 80 00 00 00 00 01 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A18
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x34
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
Physical slot #0
Presence detect yes
Link width 1x (max 2x)
PCI capability
Caps offset 0xA0
PCI capability
Caps offset 0xB0
SubVendor ID 0x1002
SubSystem ID 0x5A14
PCI capability
Caps offset 0xB8
Caps offset 0x100
Vendor ID 1
Size 16
Caps class 0xD
Caps offset 0x190
PCI registers
00 02 10 18 5A 07 00 10 00 00 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 D1 D1 00 20
20 90 FE 90 FE F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 34 01 00 00
60 00 08 00 00 22 CC 31 00 40 00 12 F0 80 25 24 00
Location bus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A19
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x34
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 1
Version 2.0
Physical slot #0
Presence detect yes
Link width 1x (max 1x)
PCI capability
Caps offset 0xA0
PCI capability
Caps offset 0xB0
SubVendor ID 0x1002
SubSystem ID 0x5A14
PCI capability
Caps offset 0xB8
Caps offset 0x100
Vendor ID 1
Size 16
Caps class 0xD
Caps offset 0x190
PCI registers
00 02 10 19 5A 07 00 10 00 00 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 C1 C1 00 20
20 80 FE 80 FE F1 FF 01 00 00 00 00 00 00 00 00 00
50 01 58 03 C8 00 01 00 00 10 A0 42 01 20 80 00 00
60 00 08 00 00 12 CC 31 01 40 00 11 70 80 25 2C 00
Location bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A1A
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x35
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 2
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0xA0
PCI capability
Caps offset 0xB0
SubVendor ID 0x1002
SubSystem ID 0x5A14
PCI capability
Caps offset 0xB8
Caps offset 0x100
Vendor ID 1
Size 16
Caps class 0xD
Caps offset 0x190
PCI registers
00 02 10 1A 5A 06 00 10 00 00 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 04 04 00 F1 01 00 20
20 70 FE 70 FE F1 FF 01 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 35 01 00 00
60 00 08 00 00 12 CC 31 02 40 00 12 F0 80 25 34 00
Location bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A1B
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x35
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 3
Version 2.0
Physical slot #0
Presence detect yes
PCI capability
Caps offset 0xA0
PCI capability
Caps offset 0xB0
SubVendor ID 0x1002
SubSystem ID 0x5A14
PCI capability
Caps offset 0xB8
Caps offset 0x100
Vendor ID 1
Size 16
Caps class 0xD
Caps offset 0x190
PCI registers
00 02 10 1B 5A 06 00 10 00 00 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 05 05 00 F1 01 00 20
20 60 FE 60 FE F1 FF 01 00 00 00 00 00 00 00 00 00
60 00 08 00 00 12 CC 31 03 40 00 12 F0 80 25 3C 00
Location bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x5A1C
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x06
Int. Line 0x35
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 4
Version 2.0
Physical slot #1
Presence detect yes
PCI capability
Caps offset 0xA0
PCI capability
Caps offset 0xB0
SubVendor ID 0x1002
SubSystem ID 0x5A14
PCI capability
Caps offset 0xB8
Caps offset 0x100
Vendor ID 1
Size 16
Caps class 0xD
Caps offset 0x190
PCI registers
00 02 10 1C 5A 06 00 10 00 00 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 06 06 00 F1 01 00 20
20 50 FE 50 FE F1 FF 01 00 00 00 00 00 00 00 00 00
60 00 08 00 00 12 CC 31 04 40 00 12 F0 80 25 4C 00
Description RAID Controller
Location bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4393
Revision ID 0x40
PI 0x00
SubClass 0x04
BaseClass 0x01
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (port) 0x0000F040
Address 1 (port) 0x0000F030
Address 2 (port) 0x0000F020
Address 3 (port) 0x0000F010
Address 4 (port) 0x0000F000
Address 5 (memory) 0xFEB0B000
Subvendor ID 0x1043
Subsystem ID 0x84DF
Int. Line 0x13
Int. Pin 0x01
PCI capability
Caps class 0x12
Caps offset 0x70
PCI capability
Caps class 0x13
Caps offset 0xA4
PCI registers
00 02 10 93 43 07 00 30 02 40 00 04 01 00 20 00 00
10 41 F0 00 00 31 F0 00 00 21 F0 00 00 11 F0 00 00
20 01 F0 00 00 00 B0 B0 FE 00 00 00 00 43 10 DF 84
30 00 00 00 00 70 00 00 00 00 00 00 00 13 01 00 00
40 14 80 80 00 01 00 20 00 00 00 80 00 00 00 00 00
50 05 70 86 00 00 00 00 00 00 00 00 00 00 00 00 00
60 01 50 22 00 00 00 00 00 00 00 00 00 00 00 00 00
70 12 A4 10 00 0F 00 00 00 28 01 00 00 31 02 00 00
80 00 00 00 00 06 1A 14 00 AB 01 08 00 F0 00 00 00
90 27 60 74 C7 02 43 06 00 00 01 00 00 01 58 B1 02
A0 0C 00 00 00 13 00 06 03 00 00 64 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00
E0 80 00 00 00 00 00 00 00 00 00 00 00 10 00 00 3F
F0 00 00 00 00 00 00 00 00 77 77 77 00 00 E0 FE CC
Description USB Controller (OHCI)
Location bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4397
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x20
Header 0x80
PCI header
Address 0 (memory) 0xFEB0A000
Subvendor ID 0x1002
Subsystem ID 0x4397
Int. Line 0x12
Int. Pin 0x01
PCI registers
00 02 10 97 43 06 00 A0 02 00 10 03 0C 10 20 80 00
10 00 A0 B0 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 97 43
30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00
40 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00
50 40 00 00 F0 00 00 00 00 10 F2 FF FF 00 00 00 00
70 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 18 (0x12), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4396
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFEB09000
Subvendor ID 0x1002
Subsystem ID 0x4396
Int. Line 0x11
Int. Pin 0x02
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0xE4
PCI registers
00 02 10 96 43 06 00 B0 02 00 20 03 0C 10 20 00 00
10 00 90 B0 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 96 43
30 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00
50 40 21 80 A0 01 00 00 00 00 00 00 00 00 00 00 00
60 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00
C0 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 19 (0x13), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4397
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x20
Header 0x80
PCI header
Address 0 (memory) 0xFEB08000
Subvendor ID 0x1002
Subsystem ID 0x4397
Int. Line 0x14
Int. Pin 0x01
PCI registers
10 00 80 B0 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 14 01 00 00
50 40 00 00 F0 00 00 00 00 43 FF FF FF 00 00 00 00
Location bus 0 (0x00), device 19 (0x13), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4396
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFEB07000
Subvendor ID 0x1002
Subsystem ID 0x4396
Int. Line 0x15
Int. Pin 0x02
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps offset 0xE4
PCI registers
10 00 70 B0 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 15 02 00 00
Description SMBus Controller
Location bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4385
Revision ID 0x42
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1002
Subsystem ID 0x4385
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 85 43 03 04 20 02 42 00 05 0C 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 85 43
Description Multimedia device
Location bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4383
Revision ID 0x40
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFEB00000
Subvendor ID 0x1043
Subsystem ID 0x84DB
Int. Line 0x10
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.1
PCI registers
00 02 10 83 43 06 00 10 04 40 00 03 04 10 20 00 00
10 04 00 B0 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 DB 84
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
40 00 00 00 00 01 10 00 00 00 00 00 00 01 00 00 00
50 01 00 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Description PCI to ISA Bridge
Location bus 0 (0x00), device 20 (0x14), function 3 (0x03)
Common header
Vendor ID 0x1002
Model ID 0x439D
Revision ID 0x40
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1002
Subsystem ID 0x439D
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 9D 43 0F 00 20 02 40 00 01 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 9D 43
40 04 00 00 00 55 C0 03 FF 07 FF 00 02 00 00 00 00
60 00 00 00 00 30 02 00 00 00 00 0F 00 C0 FF FF FF
70 67 45 23 00 08 00 00 00 1C 00 00 00 00 0B 00 00
80 08 00 03 A8 00 00 00 00 00 00 00 00 00 00 00 00
90 28 FF 00 00 00 00 00 00 00 00 00 00 01 10 D6 FE
A0 02 00 C1 FE 2E 01 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 09 39 00 00 00 00
Location bus 0 (0x00), device 20 (0x14), function 4 (0x04)
Common header
Vendor ID 0x1002
Model ID 0x4384
Revision ID 0x40
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x07
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 02 10 84 43 27 04 A0 02 40 01 04 06 00 40 81 00
10 00 00 00 00 00 00 00 00 00 07 07 40 F0 00 80 22
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
40 26 00 3C FF 00 00 00 00 0C 0F 3F D1 00 01 00 00
50 01 00 00 00 08 00 03 A8 00 00 00 00 85 00 FF FF
60 CA 0E 17 00 BA 98 10 02 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 06
E0 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 20 (0x14), function 5 (0x05)
Common header
Vendor ID 0x1002
Model ID 0x4399
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFEB06000
Subvendor ID 0x1002
Subsystem ID 0x4399
Int. Line 0x12
Int. Pin 0x03
PCI registers
00 02 10 99 43 06 00 A0 02 00 10 03 0C 10 20 00 00
10 00 60 B0 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 02 10 99 43
30 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
50 40 00 00 F0 00 00 00 00 FF FF FF FF 00 00 00 00
Location bus 0 (0x00), device 22 (0x16), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x4397
Revision ID 0x00
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x20
Header 0x80
PCI header
Address 0 (memory) 0xFEB05000
Subvendor ID 0x1002
Subsystem ID 0x4397
Int. Line 0x16
Int. Pin 0x01
PCI registers
10 00 50 B0 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 16 01 00 00
50 40 00 00 F0 00 00 00 00 65 FF FF FF 00 00 00 00
Location bus 0 (0x00), device 22 (0x16), function 2 (0x02)
Common header
Vendor ID 0x1002
Model ID 0x4396
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFEB04000
Subvendor ID 0x1002
Subsystem ID 0x4396
Int. Line 0x17
Int. Pin 0x02
PCI capability
Caps offset 0xC0
Caps version 1.1
PCI capability
Caps offset 0xE4
PCI registers
10 00 40 B0 FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 17 02 00 00
Location bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1600
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps offset 0x80
Caps revision 3.00
Interface type Host/Secondary
Device number 0
PCI registers
00 22 10 00 16 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
50 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00
60 00 00 07 00 E0 00 00 00 00 A8 4E 02 00 FE 80 00
80 08 00 01 21 20 A0 11 11 60 0C F5 FF 13 00 00 00
90 EE 02 84 80 00 00 01 00 07 00 00 00 3E 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1601
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 01 16 00 00 00 00 00 00 00 06 00 00 80 00
40 03 00 00 00 00 00 2F 04 00 00 00 00 01 00 00 00
50 00 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00
60 00 00 00 00 04 00 00 00 00 00 00 00 05 00 00 00
70 00 00 00 00 06 00 00 00 00 00 00 00 07 00 00 00
80 03 00 D0 00 00 F0 FE 00 00 00 00 00 00 00 00 00
C0 13 C0 00 00 00 F0 00 00 00 00 00 00 00 00 00 00
E0 03 00 00 1F 00 00 00 00 00 00 00 00 00 00 00 00
F0 03 30 00 D0 01 00 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1602
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 02 16 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 09 01 00 00 00 00 00 00 00 00 00 00
60 E0 3E F8 01 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 02 00 38 00 24 18
80 0A 00 00 00 04 00 80 00 00 00 00 3C 00 00 02 00
90 00 00 01 0B 96 08 48 0F 07 40 0F 8D 00 00 00 00
A0 00 02 1D 03 00 00 00 00 00 00 00 00 00 00 00 00
B0 E2 4A 34 38 13 00 00 00 9C 69 F4 BF BE F7 FE 19
D0 90 98 AB 5F 7B B3 B7 A8 09 1B 78 88 7F B6 8D DA
E0 F0 C9 C5 CA A7 E9 BE B2 DB 70 F6 FA 7C CF 23 E2
F0 00 00 00 00 00 00 00 00 D5 D7 9C 8D 6F 55 15 00
Location bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1603
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Secure Device
Caps offset 0xF0
PCI registers
00 22 10 03 16 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40 FF FF FF FF 44 00 B0 4A 00 00 00 00 00 00 00 00
60 00 00 00 00 05 00 4C 66 00 00 00 60 52 00 01 10
70 55 11 17 10 11 21 17 00 12 0E 20 00 16 0F 0D 04
80 81 E2 0B E2 E2 00 E2 01 08 00 81 00 00 40 40 00
90 40 00 00 00 1B 17 00 00 40 3A 3D 6D 00 00 00 00
A0 B8 0E 27 A0 EF 0F 60 2A 00 00 00 D0 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 EC D1 05 00
D0 00 00 00 00 00 2F 81 C8 10 00 00 03 38 56 47 05
E0 00 00 00 00 20 00 00 00 18 4F 07 02 00 00 00 00
F0 0F 00 10 00 00 00 00 00 00 00 00 00 12 0F 60 00
Location bus 0 (0x00), device 24 (0x18), function 4 (0x04)
Common header
Vendor ID 0x1022
Model ID 0x1604
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 04 16 00 00 00 00 00 00 00 06 00 00 80 00
50 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 00
Location bus 0 (0x00), device 24 (0x18), function 5 (0x05)
Common header
Vendor ID 0x1022
Model ID 0x1605
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 22 10 05 16 00 00 00 00 00 00 00 06 00 00 80 00
80 0F 00 0F 00 07 30 16 00 00 40 00 00 00 00 00 00
B0 28 23 00 00 AD 25 00 00 00 00 00 00 6B 09 00 00
E0 0E 00 00 00 00 00 00 00 FC 00 00 00 71 00 02 00
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x6719
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xD0000000
Address 2 (memory) 0xFEA20000
Address 4 (port) 0x0000E000
Subvendor ID 0x1787
Subsystem ID 0x2307
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Device type Legacy PCI-E Endpoint Device
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps class Advanced Error Reporting
Caps offset 0x150
PCI registers
00 02 10 19 67 07 04 10 00 00 00 00 03 10 00 80 00
10 0C 00 00 D0 00 00 00 00 04 00 A2 FE 00 00 00 00
20 01 E0 00 00 00 00 00 00 00 00 00 00 87 17 07 23
30 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 87 17 07 23
50 01 58 03 06 00 00 00 00 10 A0 12 00 A1 8F 2C 01
60 00 29 09 00 02 0D 00 00 40 00 02 11 00 00 00 00
80 00 00 00 00 00 00 00 00 02 00 01 00 00 00 00 00
A0 05 00 81 00 0C F0 EF FE 00 00 00 00 B0 49 00 00
100 0B 00 01 15 01 00 01 01 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0xAA80
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFEA40000
Subvendor ID 0x1787
Subsystem ID 0xAA80
Int. Line 0x19
Int. Pin 0x02
PCI capability
Caps offset 0x50
Caps version 1.2
PCI capability
Caps offset 0x58
Port 0
Version 2.0
PCI capability
Caps offset 0xA0
Caps offset 0x100
Vendor ID 1
Size 16
Caps offset 0x150
PCI registers
00 02 10 80 AA 06 00 10 00 00 00 03 04 10 00 80 00
10 04 00 A4 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 87 17 80 AA
30 00 00 00 00 50 00 00 00 00 00 00 00 19 02 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 87 17 80 AA
80 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00
A0 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Description Serial ATA Controller
Location bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x0612
Revision ID 0x01
PI 0x01
SubClass 0x06
BaseClass 0x01
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000D050
Address 1 (port) 0x0000D040
Address 2 (port) 0x0000D030
Address 3 (port) 0x0000D020
Address 4 (port) 0x0000D000
Address 5 (memory) 0xFE900000
Subvendor ID 0x1043
Subsystem ID 0x84B7
Int. Line 0x2C
Int. Pin 0x01
PCI capability
Caps offset 0x50
PCI capability
Caps offset 0x78
Caps version 1.2
PCI capability
Caps offset 0x80
Port 1
Version 2.0
Caps class Virtual Channel
Caps offset 0x100
PCI registers
00 21 1B 12 06 07 00 10 00 01 01 06 01 10 00 00 00
10 51 D0 00 00 41 D0 00 00 31 D0 00 00 21 D0 00 00
20 01 D0 00 00 00 00 90 FE 00 00 00 00 43 10 B7 84
30 00 00 00 00 50 00 00 00 00 00 00 00 2C 01 00 00
40 00 00 00 00 60 61 11 02 00 00 00 00 00 00 00 00
50 05 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 11 78 01 00 00 00 00 00
70 00 00 00 00 00 00 00 00 01 80 03 00 00 00 00 00
80 10 00 12 00 02 87 2C 01 00 28 01 00 12 B0 00 01
90 40 00 12 10 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 17 00 00 00 00 00 00 00 00 00 00 00
B0 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 33 01 00 00 63 00 00 00
F0 FF FF 00 00 10 00 00 00 00 00 00 00 00 00 00 00
100 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
Description Ethernet Controller
Location bus 3 (0x03), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x150C
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE800000
Address 3 (memory) 0xFE820000
Subvendor ID 0x1043
Subsystem ID 0x8457
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0xC8
Caps version 1.1
PCI capability
Caps offset 0xD0
PCI capability
Caps offset 0xE0
Device type PCI-E Endpoint Device
Port 1
Version 1.0
PCI capability
Caps class MSI-X
Caps offset 0xA0
Caps offset 0x100
Caps class Device Serial Number
Caps offset 0x140
PCI registers
00 86 80 0C 15 06 04 10 00 00 00 00 02 10 00 00 00
10 00 00 80 FE 00 00 00 00 01 00 00 00 00 00 82 FE
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 57 84
30 00 00 00 00 C8 00 00 00 00 00 00 00 00 01 00 00
A0 11 00 00 80 03 00 00 00 03 20 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 01 D0 22 C8 00 21 00 0F
D0 05 E0 80 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 10 A0 01 00 C1 8C 00 00 00 28 19 00 11 1C 03 01
F0 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 14 00 00 00 00 00 00 00 00 11 20 06 00
110 00 20 00 00 00 20 00 00 00 00 00 00 00 00 00 00
Location bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x1042
Revision ID 0x00
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE700000
Subvendor ID 0x1043
Subsystem ID 0x8488
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
PCI capability
Caps class MSI-X
Caps offset 0x68
PCI capability
Caps offset 0x78
Caps version 1.2
PCI capability
Caps offset 0x80
Port 1
Version 2.0
Caps offset 0x100
PCI registers
00 21 1B 42 10 06 04 10 00 00 30 03 0C 10 00 00 00
10 04 00 70 FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 88 84
50 05 68 86 00 00 00 00 00 00 00 00 00 00 00 00 00
60 30 20 00 00 00 00 00 00 11 78 07 80 00 20 00 00
70 80 20 00 00 00 00 00 00 01 80 43 C0 00 00 00 00
80 10 00 12 00 02 82 2C 01 00 28 01 00 12 FC 03 01
F0 00 00 00 00 00 00 00 00 62 00 00 00 00 00 00 00
Location bus 5 (0x05), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x1042
Revision ID 0x00
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE600000
Subvendor ID 0x1043
Subsystem ID 0x8488
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
PCI capability
Caps class MSI-X
Caps offset 0x68
PCI capability
Caps offset 0x78
Caps version 1.2
PCI capability
Caps offset 0x80
Port 1
Version 2.0
Caps offset 0x100
PCI registers
10 04 00 60 FE 00 00 00 00 00 00 00 00 00 00 00 00
Location bus 6 (0x06), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1B21
Model ID 0x1042
Revision ID 0x00
PI 0x30
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFE500000
Subvendor ID 0x1043
Subsystem ID 0x8488
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps offset 0x50
PCI capability
Caps class MSI-X
Caps offset 0x68
PCI capability
Caps offset 0x78
Caps version 1.2
PCI capability
Caps offset 0x80
Port 1
Version 2.0
Caps offset 0x100
PCI registers
10 04 00 50 FE 00 00 00 00 00 00 00 00 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version 1301
date 03/12/2012
DMI System Information
manufacturer To be filled by O.E.M.
product To be filled by O.E.M.
version To be filled by O.E.M.
serial To be filled by O.E.M.
UUID {DC3A2560-8DF3-11E0-A639-F46D0454F024}
DMI Baseboard
vendor ASUSTeK COMPUTER INC.
model Crosshair V Formula
revision Rev 1.xx
serial 110104030000086
DMI System Enclosure
manufacturer To Be Filled By O.E.M.
chassis type Desktop
chassis serial To Be Filled By O.E.M.
DMI Processor
manufacturer AMD
model AMD FX(tm)-8150 Eight-Core Processor
clock speed 4600.0 MHz
FSB speed 200.0 MHz
multiplier 23.0x
DMI Port Connector
designation J1A1 (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation J2A1 (internal)
designation TV Out (external)
connector Mini Centronics Type-14
DMI Port Connector
designation J2A2A (internal)
designation COM A (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation J2A2B (internal)
designation Video (external)
port type Video Port
connector DB-15 female
DMI Port Connector
designation J3A1 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (external)
port type USB
DMI Port Connector
designation J9A1 - TPM HDR (internal)
DMI Port Connector
designation J9C1 - PCIE DOCKING CONN (internal)
DMI Port Connector
designation J2B3 - CPU FAN (internal)
DMI Port Connector
designation J6C2 - EXT HDMI (internal)
DMI Port Connector
designation J3C1 - GMCH FAN (internal)
DMI Port Connector
designation J1D1 - ITP (internal)
DMI Port Connector
designation J9E2 - MDC INTPSR (internal)
DMI Port Connector
designation J9E4 - MDC INTPSR (internal)
DMI Port Connector
designation J9E3 - LPC HOT DOCKING (internal)
DMI Port Connector
designation J9E1 - SCAN MATRIX (internal)
DMI Port Connector
designation J9G1 - LPC SIDE BAND (internal)
DMI Port Connector
designation J8F1 - UNIFIED (internal)
DMI Port Connector
designation J6F1 - LVDS (internal)
DMI Port Connector
designation J2F1 - LAI FAN (internal)
DMI Port Connector
designation J2G1 - GFX VID (internal)
DMI Port Connector
designation J1G6 - AC JACK (internal)
DMI Extension Slot
designation J6B2
type A5
populated yes
DMI Extension Slot
designation J6B1
type A5
populated yes
DMI Extension Slot
designation J6D1
type A5
populated yes
DMI OEM Strings
string[0] To Be Filled By O.E.M.
string[1] To Be Filled By O.E.M.
string[2] To Be Filled By O.E.M.
string[3] To Be Filled By O.E.M.
DMI Physical Memory Array
location Motherboard
usage System Memory
correction Multi-bit ECC
max capacity 32768 MBytes
max# of devices 4
DMI Memory Device
designation DIMM0
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
DMI Memory Device
designation DIMM1
format DIMM
type unknown
data width 64 bits
DMI Memory Device
designation DIMM2
format DIMM
type unknown
total width 64 bits
data width 64 bits
size 8192 MBytes
DMI Memory Device
designation DIMM3
format DIMM
type unknown
data width 64 bits
Graphics
Number of adapters 1
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Name AMD Radeon HD 6900 Series
Memory size 1024 MB
GPU ref clock 27000
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1787)
Model ID 0x6719 (0x2307)
Performance Level 0
Software
Windows Version Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
ACPI
ACPI Tree
_GPE
_L1B
_L03
_L04
_L0B
_L0F
_L10
_L11
_L12
_L18
_L05
_PR_
SSDT
DCOR
TBLD
NPSS
HNDL
APSS
P001
TYPE
_PDC
_CST
_CSD
P002
TYPE
_PDC
_CST
_CSD
P003
TYPE
_PDC
_CST
_CSD
P004
TYPE
_PDC
_CST
_CSD
P005
TYPE
_PDC
_CST
_CSD
P006
TYPE
_PDC
_CST
_CSD
P007
TYPE
_PDC
_CST
_CSD
P008
TYPE
_PDC
_CST
_CSD
_SB_
PR00
AR00
PR20
AR20
PR21
AR21
PR22
AR22
PR23
AR23
PR12
AR12
PR14
AR14
PR15
AR15
PR16
AR16
PR17
AR17
PR19
AR19
PR1A
AR1A
PR1B
AR1B
PR1C
AR1C
PR1D
AR1D
PR0C
AR0C
PRSA
PRSB
PRSC
PRSD
PRSE
PRSF
PRSG
PRSH
PCI0
_HID
_ADR
_BBN
_UID
_PRT
CPRB
LVGA
BRB_
BRL_
IOB_
IOL_
MBB_
MBL_
MABL
MABH
MALL
MALH
MAML
MAMH
CRS1
CRS2
_CRS
AMDN
_HID
_UID
_STA
NPTR
_CRS
NPTS
NWAK
SMBS
_ADR
SMBS
REV_
I1F_
I12F
MT3A
EIDX
EDAT
G39E
G41E
G39O
G41O
WIDE
DUM1
SOPT
GPIO
G06E
G06O
G06I
G07B
G0BB
G0EB
G14E
G14O
G14I
G15E
G15O
G15I
G1CI
G2DE
G2DO
G2DI
G35E
G35O
G37E
G37O
G37I
GE05
GE15
GE16
GE22
GAAE
GAAO
GAAI
GAFB
GB0B
GPMX
G06M
G07M
G0BM
G0EM
G14M
G15M
G1CM
G2DM
G37M
G70M
G76M
GAFM
GB0M
IDEC
_ADR
UDMT
PIOT
PITR
MDMT
MDTR
IDE_
PPIT
SPIT
PMDT
SMDT
PPIC
SPIC
PPIM
SPIM
PUDC
SUDC
PUDM
SUDM
GETT
GTM_
STM_
GTF_
PRID
_ADR
_GTM
_STM
P_D0
_ADR
_GTF
P_D1
_ADR
_GTF
SECD
_ADR
_GTM
_STM
S_D0
_ADR
_GTF
S_D1
_ADR
_GTF
SBAZ
_ADR
PCI_
DNSP
DNSO
ENSR
_PRW
SBRG
_ADR
RMBS
LR2S
LR2E
SMIP
SMIC
GPIO
CLPS
SLPS
FSCR
FSSR
ALLS
SPTS
SWAK
IPTS
S800
_HID
_UID
_STA
CRS_
_CRS
SIO1
_HID
_UID
CRS_
_CRS
DCAT
MUT0
ENFG
EXFG
LPTM
UHID
IOID
INDX
DATA
LDN_
SCF1
SCF2
SCF3
SCF4
SCF5
SCF6
CKCF
ACTR
IOAH
IOAL
IOH2
IOL2
INTR
DMCH
OPT0
OPT1
OPT2
OPT3
OPT4
OPT5
OPT6
CGLD
DSTA
DCNT
CRS1
IRQM
DMAM
IO11
IO12
LEN1
CRS2
IRQE
DMAE
IO21
IO22
LEN2
IO31
IO32
LEN3
CRS4
IRQL
IRQS
IOHL
IORL
ALMN
LENG
DCRS
DCR2
DCR4
DSRS
DSR2
DSR4
PMFG
SIOS
SIOW
SIOH
EC0_
_HID
_CRS
DPRT
CPRT
_GPE
REGC
_Q80
_Q81
_Q82
_Q83
PIC_
_HID
_CRS
DMAD
_HID
_CRS
TMR_
_HID
_CRS
RTC0
_HID
_CRS
SPKR
_HID
_CRS
RRIO
RDMA
RMSC
_HID
_UID
CRS1
CRS2
_CRS
COPR
_HID
_CRS
NBRM
_HID
_UID
CRS_
_CRS
PS2K
_HID
_CID
_STA
_CRS
_PRS
_PSW
_PRW
PS2M
_HID
_CID
_STA
CRS1
CRS2
_CRS
_PRS
_PSW
_PRW
S3RS
SLIC
SLI4
WMI1
_HID
_UID
_WDG
WMMX
P0PC
_ADR
_PRW
_PRT
UHC1
_ADR
_PRW
UHC2
_ADR
_PRW
USB3
_ADR
_PRW
UHC4
_ADR
_PRW
USB5
_ADR
_PRW
UHC6
_ADR
_PRW
UHC7
_ADR
_PRW
SATA
_ADR
_INI
SACS
STB5
SPTM
PRID
_ADR
_GTM
_STM
_STA
PRIS
_PS0
_PS3
_PSC
P_D0
_ADR
_STA
S12P
_PS0
_PS3
_PSC
P_D1
_ADR
_STA
S12P
_PS0
_PS3
_PSC
SECD
_ADR
_GTM
_STM
SECS
_STA
_PS0
_PS3
_PSC
S_D0
_ADR
_STA
S12P
_PS0
_PS3
_PSC
S_D1
_ADR
_STA
S12P
_PS0
_PS3
_PSC
PE20
_ADR
_PRW
_PRT
PE21
_ADR
_PRW
_PRT
PE22
_ADR
_PRW
_PRT
PE23
_ADR
_PRW
_PRT
IOMA
_ADR
NBF2
DID_
MBAS
UMEM
_HID
_UID
CRS_
_CRS
RD8A
_ADR
NB2_
MI__
MD__
HI__
HD__
API_
APD_
NMEM
_HID
_UID
CRS_
_CRS
PC02
_ADR
_PRW
_PRT
PC04
_ADR
_PRW
_PRT
PC05
_ADR
_PRW
_PRT
PC06
_ADR
_PRW
_PRT
PC07
_ADR
_PRW
_PRT
PC09
_ADR
_PRW
_PRT
PC0A
_ADR
_PRW
_PRT
PC0B
_ADR
_PRW
_PRT
PC0C
_ADR
_PRW
_PRT
PC0D
_ADR
_PRW
_PRT
_INI
BN00
PWRB
_HID
_UID
_STA
_PRW
PIRQ
PIDX
PDAT
PIRA
PIRB
PIRC
PIRD
PIRE
PIRF
PIRG
PIRH
PIRS
HDAD
GEC_
USB1
USB2
USB3
USB4
USB5
USB6
USB7
IDE_
SATA
GPP0
GPP1
GPP2
GPP3
KBDD
PD64
IRQC
INTA
INTB
INTC
INTD
BUFA
IPRA
IPRB
IPRC
IPRD
LNKA
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKB
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKC
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKD
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKE
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKF
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKG
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
LNKH
_HID
_UID
_STA
_PRS
_DIS
_CRS
_SRS
RMEM
_HID
_UID
RAMB
DSAF
PAR0
PAR1
PAR2
PINX
PADD
MPAR
ARBF
REAX
REBX
RECX
REDX
IOB2
SMIC
SMIS
ISMI
GMSR
SMSR
PRID
GPRE
GNVS
SNVS
SARM
GAMM
SAMM
_SI_
_TZ_
_REV
_OS_
_OSI
_GL_
SP1O
IO1B
IO1L
IO2B
IO2L
IO3B
IO3L
SMBB
SMBL
SMB0
SMBM
PMBS
PMLN
SMIO
GPBS
GPLN
APCB
APCL
SPIB
SPIL
HPTB
HPTL
GIOB
IOMB
SMIB
ACPH
ASSB
AOTB
AAXB
SHPC
PEPM
PEER
PECS
ITKE
MBEC
AMWV
PEBS
PEBL
SMIP
PEHP
PICM
_PIC
OSVR
OSFL
MCTH
PRWP
GPRW
WAKP
DEB0
DBG8
DEB1
DBG9
SS1_
SS2_
SS3_
SS4_
IOST
TOPM
ROMS
VGAF
OSTY
ACMS
ICMS
DCMS
P80_
BS_A
CFGS
PCIE
GGN2
GECE
IR_E
OSCF
PRS0
DET0
PRS1
DET1
PRS2
DET2
PRS3
DET3
ABPS
GPPS
CMPT
CMID
GPCT
GP0I
GP1I
GP2I
GP3I
GP4I
GP5I
GP6I
GP7I
PCFG
PMSA
PMSB
PMSC
STCL
SMIE
SMME
RVID
SMB1
G31O
ACIR
PCMD
PMS0
TLS0
PMS1
TLS1
PMS2
TLS2
PMS3
TLS3
PMIO
INPM
DAPM
MMSO
P1EB
ERMM
GP51
GP55
GP59
GP62
GP64
GE11
GE12
BATS
CLPS
G15A
SLPS
EPNM
DPPF
PWDE
ALLS
PHYD
US5R
GECD
ABIO
INAB
DAAB
RDAB
WTAB
RWAB
CABR
GENC
GHPS
GEN2
GEN1
P1E0
PEWS
WSTA
PEWD
SPTS
SWAK
TRMD
CPMS
KBFG
MSFG
HPET
_HID
CRS_
_STA
_CRS
WOTB
WSSB
WAXB
_PTS
_WAK
IORK
IOWK
OMSC
_HID
_UID
AMW0
_HID
_UID
_WDG
CCAC
ECD2
EID2
WED2
WMBC
RSMB
WSMB
RSMW
WSMW
RSMK
WSMK
WMBD
_WED
AMWR
AMWN
WQMO
SPEC
DEVP
SDSP
GDSP
DEVS
DSTS
GPID
KBFT
HKEY
CFVS
CFVG
RAMW
WBYT
W2YT
RBYT
R2YT
SMRG
HSTS
SSTS
HSTC
HCMD
HADR
HDT0
HDT1
BLKD
H2TS
S2TS
H2TC
H2MD
H2DR
H2T0
H2T1
ASCM
A2CM
_S0_
_S1_
_S3_
_S4_
_S5_
PTS_
WAK_
# of P-States 7
but better set setings auto, not OC (I see non stock ratios).
Beep, will be tab updated? Example my second FX-8150 :). Thx.
This chip has given me hope it doesnt like voltage right now I am priming http://thumbnails61.imagebam.com/193...7193483413.jpg
batch?
some info about enxt 2012 batchs? Did someone tested it with LN2?
FX-8150 FA 1217 PGN
***Reserving Spot for Future Overclocks***
Current Clocking::.
200*20=4.0ghz @ stock voltage / HT 2600 / NB 2600 (I think 2600 is stock clock for HT, and NB ... Can't seem to find the specs anywhere) Zalman 9700 @ ~95F
ASUS Crosshair V Formula w/ Thunderbolt
8gb GSkill Sniper 1866 Stock Timings
XFX 6950 2gb (Will not flash :( )
Intel x25 80gb SSD
1x1TB 2x500gb WD Caviar Black
PCP&C Silencer MKIII 750w
CoolerMaster Sniper w/ added 140mm fan in bottom (Makes a bigger difference then I realized)
http://i258.photobucket.com/albums/h...1543/40ghz.jpg
What volts r u guys running to reach 2500-2600 CPU/nb and HT?
Currently at 2375mhz with 1.225v for CPU/nb and ht is on auto
HT auto, CPU/NB 1.3V 2650 MHz
I'm still running mine at stock speeds lol
I've got an FX 8120
The heat is too high 48C is what I been getting on load. I've got an H60 with push/pull fans. (their 9 blade 110CFM fans)
The stock Cpu-Core VID is 1.3 volts and cpu NB Vid Is 1.2 volts.
I have disable APM,C1E,C6. and only have cool and quite enabled.
running it at stock 3.1ghz core 2.2ghz NB
I'm down to 1.2250 cpu core VID and 1.075 cpu NB VID
from about 36C load to 41C load.
