I thought it was white tubes lol
Ice Dragon Cooling nanofluid. It looks a lot more solid white than milk.
Wait till you see my next one. http://smiliesftw.com/x/kdubb.gif
If I want to do a full white setup again I'll be using white tubes next time. All clear tubing is crap. After a few months it discolours or clouds and generally looks nasty.
For real clear tubes looks like crap I use red ones :)
obsidian 800d r.o.g. edition
http://www.xtremeshack.com/immagine/...385866-003.jpg
http://www.xtremeshack.com/immagine/...2-sl385924.jpg http://www.xtremeshack.com/immagine/...1-sl386023.jpg http://www.xtremeshack.com/immagine/...3-sl385975.jpg http://www.xtremeshack.com/immagine/...4-sl385978.jpg
http://www.xtremeshack.com/immagine/...1-sl385951.jpg http://www.xtremeshack.com/immagine/...8-sl385948.jpghttp://www.xtremeshack.com/immagine/...9-sl385968.jpg
http://www.xtremeshack.com/immagine/...0-sl385970.jpg http://www.xtremeshack.com/immagine/...8-sl386011.jpg http://www.xtremeshack.com/immagine/...7-sl386009.jpg
http://www.xtremeshack.com/immagine/...7-sl385986.jpg http://www.xtremeshack.com/immagine/...1-sl385999.jpg http://www.xtremeshack.com/immagine/...4-sl386004.jpg http://www.xtremeshack.com/immagine/...5-sl386005.jpg
http://www.xtremeshack.com/immagine/...3-sl386053.jpg http://www.xtremeshack.com/immagine/...1-sl386047.jpg
more info
Obsidian 800d R.O.G. -> liberato87 - Xtreme Hardware Forum
http://i288.photobucket.com/albums/l...xforces/c5.jpg
http://i288.photobucket.com/albums/l...%20path/g6.jpg
http://i288.photobucket.com/albums/l...0path/g3-1.jpg
http://i288.photobucket.com/albums/l...0path/i3-1.jpg
http://i288.photobucket.com/albums/l...0path/i1-1.jpg
http://i288.photobucket.com/albums/l...0path/i2-1.jpg
wow.
black and gold...
uncommon and well executed....
me likes
thanks guys!;)
After about 3-4 years of WCing, im back at Aircooling with a build i called Mini-B.
Im not gaming that much anymore and i decided to invest in something else than a computer, in futur, house and more !
So here it is ! My new small thing. Ill in the proces of finding a new GPU or two, maybe GTX670's
I alwais wanted to try an mATX build.
I first of put everything inside this new little case and had trouble with the TPQ-1200-OC. I have this PSU for ~2yrs now and it served me very well when i had SLI GTX580 and an I7 920, All WCed and OCed but now that i reduce the rig, its a bit overkill. But the main issue is with the powercache, the big thing on the cables that hold capacitors. They just dont fit very well behind the backpanel of this little case ...
http://www.infodupat.com/MiscPics/DSCF2903.JPG
http://www.infodupat.com/MiscPics/DSCF2904.JPG
http://www.infodupat.com/MiscPics/DSCF2905.JPG
The easyest was to leave them on the floor cause they dont fit behind, the back panel just wont close ...
http://www.infodupat.com/MiscPics/DSCF2906.JPG
Sell the TPQ-1200-OC or mod ? Mod it for sure :)
I removed 2 of the PCIe cables and the second CPU 8pin, this still leave me a second PCIe extension and the 2 modular that i can add ( Still 8 pcie connector total ... ). I can still solder them inside if needed.
There it is ! I think its OK for now.
http://www.infodupat.com/MiscPics/DSCF2914.JPG
http://www.infodupat.com/MiscPics/DSCF2916.JPG
http://www.infodupat.com/MiscPics/DSCF2917.JPG
http://www.infodupat.com/MiscPics/DSCF2919.JPG
Sorry i have too much pics.
New chassis: bought a Lian-Li PC-9F. I like it a lot more than my old PC-K58W.
There's also an album: http://imgur.com/a/XfC2C#0
http://i.imgur.com/pMHBJ.jpg
Hey guys
My updated CM. The project is at 80%
Hardware...
http://www.overclock.net/image/id/24...600/height/450
During the assembly...
Pictures from different angles :D
http://www.overclock.net/image/id/24...525/height/700
Screws will be black :D
More pictures soon ;)
Fredz77 love the setup and the Bonsai...
Nothing too fancy in the build or photography, but mine none the less -
http://i.minus.com/ibrQT4H2YBwXNK.jpg
http://i.minus.com/iVHRuELQIhZuA.jpg
http://i.minus.com/iTV4wQgbJKJiJ.jpg
http://i.minus.com/iSOjafRH4H8av.jpg
2 more pics, a little better this time :-) -
(Click for full-size image)
http://i.minus.com/ipFyBtIsUcVi7.jpg
http://i.minus.com/i82W7UZaJqotA.jpg
I´ve got a new case from cougar, named "Volant" It looks like this:
http://www.abload.de/img/img_6461j0rgd.jpg
http://www.abload.de/img/img_6463w6pps.jpg
http://www.abload.de/img/img_6466n4r86.jpg
http://www.abload.de/img/img_6474q5oqp.jpg
i know my rig is not as impressive as some on here but here is mine :)
Corsair 550d case
Corsair AX850 watt psu
Gigabyte Z77 UD5 mobo
Corsair vengeance 1600mhx memory 9.9.9.24 1.5v
Intel i5 2500k oc @4.5ghz (70c) max low fans (silent gaming)
Corsair h100 cpu cooler
Gigabyte windforcex3 gtx 670 2gb (stock oc)
Corsair gt 120gb force 3 ssd (windows)
Corsair 240gb force 3 ssd (games)
ZNXT mesh fan controller
5x Corsair sp120mm case fans
LG blu ray dvd rom
Samsung dvd rom/writer
Attachment 128327Attachment 128328Attachment 128329Attachment 128330Attachment 128331Attachment 128332
can i ask is that the corsair static pressure or air flow series fans you using i'm using the static pressure ones but due to my h100 cooler been a total pain
(getting one that does not have a grinding noise) i went to air cooling now i'm thinking about changing to the air flow edition
the change is from a corsair h100 cpu cooler to an prolimatech armageddon
ps love the rig nice and neat :)
Attachment 128778
