Cant remember how long after the 780 a Ti was released?
Looking to buy a GTX 980 8GB or Ti when they are out, any estimates or guestimates when these might be available?
Already using a GTX 780 3GB just now.
It's looking like there won't be a "Ti" version mainly due to the fact that the 980 is a fully enabled chip as no SMX units have been disabled or cut off hence if they did bring out a 980 Ti they would need to call it something completely different as it would be a completely different core i.e GM200.
As for the 8GB 980's they will probably follow the same pattern as the 780, Coming out only a couple of months before the next generation of GPU's but I have had a lengthy talk with a local retailer *OCUK* and they are in constant talks with vendors and no one currently has plans to make 8GB versions.
Like Titan II?:)
