The only thing changed with this bios is the new Intel Raid Rom has been inserted for the older one.
I am getting lock ups while gaming with my new cards. Is there a voltage I need to bump up to run to OC'd 7970's? I just want to rule out issues here. I have tried both cards solo, diff slots etc.
Little question: when Asus AI suite tells me the voltage is set at 1.37v, but then AIDA says it's 1.42v... Which should I believe?
never mind..
Can some please post a simple 4.8~5Ghz OC guide ? i am really confused with all the motherboard settings.
Attachment 124580This is for my 3820: Go to CPU Performance Settings. Set CPU Ratio to 39. Disable SoeedStep. Go back to the first menu, Set Ratio again to 39. BCLK to 125 & look at the RAM Speed & choose your prefered clocks. Look down to the CPU Voltages & pick something higher than stock.
Hope this help :)
This is funny because I've been telling people pretty much the same thing. The board does a great job with most UEFI settings just set to AUTO. Aside from setting XMP for memory if needed, not much else needed. Of course custom tweaking gets you further.
Here is a good guide for further tweaking:
http://www.xtremesystems.org/forums/...r-Overclocking
Thank you BigRigDriver, i know these setting its easy, what i meant is this complicated settings,
>DIGI+ Power Control
CPU VCore
CPU Load-line Calibration
CPU Current Capability
CPU Voltage Frequency
CPU Fixed Frequency
VRM Over Temperature Protection
CPU Power Duty Control
Vcore MOS volt. Control
CPU Power Phase Control
CPU VCORE Boot Up Voltage
CPU VSA
VCCSA Load-line Calibration
VCCSA Current Capability
VCCSA Fixed Frequency
CPU VCCSA Boot Up Voltage
CPU VTT
CPU VTT Switching Freq
CPU VTT Over-Current Protection
DRAM Voltage
DRAM-AB Current Capability
DRAM-AB Voltage Frequency
DRAM-AB Fixed Frequency Mode
DRAM-AB Power Phase Control
DRAM-CD Current Capability
DRAM-CD Voltage Frequency
DRAM-CD Fixed Frequency Mode
DRAM-CD Power Phase Control
PCH 1.1V
PCH 1.1V Switching Freq
Extreme OV
BCLK Skew
CPU VCORE Voltage
CPU VCORE Manual Voltage
VTT CPU Voltage
2nd VTTCPU Voltage
CPU VCCSA Voltage
CPU VCCSA Manual Voltage
DRAM Voltage (CHA, CHB)
DRAM Voltage (CHC, CHD)
CPU PLL Voltage
PCH 1.1v Voltage
VTTDDR Voltage (CHA, CHB)
VTTDDR Voltage (CHC, CHD)
CPU Spread Spectrum
PCIE Spread Spectrum
LardArse, man you method work like magic :up:
Attachment 124581
Do you have another easy way to push my memory to 2400Mhz ? and what timing (original timing 9-11-10-28) ?
Thank you very much man, i used this
F5
set 48x
set 2400 dram freq
DRAM Timing control 'Load Hynix profile' - yes
save exit
And its work very well :up:
Attachment 124582
one more thing please, can i push to 5Ghz with the same easy way ?
Also can I tighten more the memory timing ? what timing i can set ?
I use 0013 bios .
Raja or Shamino, any idea what's up with the ROG forums?? It's been down since Friday night :(
5Ghz :up:
Attachment 124590
I have only one concern about this way to OC, it is the very high Vcore (1.56), which increase the temp.
I can see some guys can do 5Ghz with only 1.43~1.45V.
New toy to play with for a while.
http://img13.imageshack.us/img13/8739/nubo.png
Uploaded with ImageShack.us
160 bclk always looks nice but won't push 3820 to any new highscores...125er strap seem to run better...
3820 is like 2600K on pcie-steroids...not more...
Something to play with until IB comes out though. Im actually testing memory kits, I knew the chip was good for 160+.
http://img407.imageshack.us/img407/1361/mushkin.png
Another New BIOS 0015
http://www.datafilehost.com/download-3f35ecb6.html
Improved DRAM OC (specially 2Dimm /channel) at least for me
First OC on new 3930K C2 and RIVE (0013) & custom WC loop. Good ? Bad ? Average ? I just keep chanting in my head "don't run prime, don't run prime"... ;-) Aida stability test at 45 mins at this point, gonna call an hour good since this thing does SP32M, CineBench, and SpecAPC for Lightwave without a hitch (and fast as hell).
Attachment 124602
