well this looks like the max for now ;)
http://valid.canardpc.com:80/show_oc.php?id=506108
http://valid.canardpc.com/cache/banner/506108.png
still havent dropped HT/NB, thats usually good for another 100-200mhz.
2 hours prime stable, currently running 3.8 prime test, sorry takes time, once I jot down all my stable speeds I will get to benching.
It's scaling almost identical voltage wise to pass prime as my week 48 940 BE
http://members.cox.net/nfridenti/720BE5.JPG
identical scaling to my 940, I will try higher + tweaked tommorow.
http://members.cox.net/nfridenti/720BE6.JPG
Dumo I know you are curious so I ran 05, haven't run it yet with 4850's in X fire, so no clue what to expect, untweaked preety dirty run, stuff in background etc etc.
http://members.cox.net/nfridenti/720BE7.JPG
Off to bed now, my finger needs to heal for saturdays DI session.
Awesome, what temps is it priming at.. 3.8 at 1.440 is excellent! :D
Also have you tried playing with the bus speed and multi, i ve seen some decent results where both were changed, system more stable with the bus at like 230 ish and lower multi.. but your the expert atm :)
Oh dear, here comes the flood of 'my god it's full of bugs' and all sorts of things blown out of proportion.
CPUs have bugs, they are very rare and only in certain cases have those bugs been serious enough to warrant a change in product roll out or PR for a company. Intel suffered this with the famous FDIV bug and the 1.13 GHz Pentium III fiasco. AMD recently suffered from this with the TLB errata...
However, those cases are rare and does not mean bugs do not exist. AMD's AM3 socket is new, expect some minor quirks until BIOS tweaking/tuning/debugging addresses most of them, and in cases where BIOS cannot address the issue the rate of occurrence is likely such a rarity you will never see it... case in point the stupid whoopla on the TLB errata that is utterly a non-issue on DTs.
Jack
Just chasing max stable core clock speeds atm with nothing else to cause issues, I will tweak it tommorow. that was 3.6 at 1.44, needs 1.55-1.575 for 3800+, this board requires more voltage than most though, 4 phase pwm.
This board tends to be a little flakey plus I need bus 267 for my ram to be 1066 or its pointless. That makes multi jumps rather awkward, 133.5 mhz per 1/2 multi, also hinders tweaking HT/NB speeds.
All dress up, but still waiting for cpu:(
http://img11.imageshack.us/img11/202...shot015tg3.jpg
I'm thinking to cross the border to pick up 945ES, but have to work Sat. am:(
If it based on M4A79D performance with 940 then this mobo should be one of the best, especially with its power stability.
The 710 and 720 have been on newegg for 3 days, so if you guys want one...
That's odd, I thought you ordered yours earlier in the day than I did. Mine was shipped yesterday. I didn't pay to "rush" it either... I've found that's a waste, I always had to call and ask for a refund (which they gave me because it didn't ship till the next day or sometimes two days later :rolleyes:)
At anyrate, mine will be here on Tuesday. :eek:
Time for more extensive results, bear with me the first tests I'm trying to get an idea of what I should expect under DI tommorow.
I seem to have a NB issue not sure if bios related, I'm not using higher because I get a post code error 00 with anything over 2200.....not by choice.
according to hardware bot these scores are spot on if not a tad faster at the same speed.
http://members.cox.net/nfridenti/720BE8.JPG
http://members.cox.net/nfridenti/720BE9.JPG
http://members.cox.net/nfridenti/720BE10.JPG
http://members.cox.net/nfridenti/720BE11.JPG
http://members.cox.net/nfridenti/720BE12.JPG
http://members.cox.net/nfridenti/720BE13.JPG
http://members.cox.net/nfridenti/720BE14.JPG
The 920's were binned with much weaker NB than the 940's. most 920's dont want to go past 2200 or so with 1.35v without errors.
It sounds like the 720's may have the same low Binned NB of the 920's. If thats true I wonder what they might be saving the Higher binned NB/tri cores for.
one things for sure, The 720 is going to appeal to allot of enthusiast and gamers at this price. Performing like a good Intel Dual core + an extra thread makes it almost as good as a quad for gaming and most desktop apps.
Its an awsome budget chip, definitely gets my vote.:up: very fun to play with.
My ISP must be in fits right now, my webspace is getting hammered with views from all the screenshots :D
Preety cold out right now what say we try to take down the current air record for 720 BE ;)
Yeah I ordered mine within 30 min of it appearing on neweg (yes I was checking newegg every 30 min)
They do this crap to me every time I really need a package, and every time I don't need it they never fail to get it to me next day. :rolleyes:
(sorry for thread crapping with my whining chew)
