https://imagizer.imageshack.com/v2/8...921/Sdgw9G.jpg
https://i.imgur.com/kWFWemP.jpg
edit: updated pic after the card swap and liquid cooling added to the GTX 1080 that was put in place of the RTX 2080 TI which went to the gaming rig.
I half assed the liquid cooling in this system as it was an after thought since it was originally AIO cooled till the second AIO cooler in a row failed on it. (avoid Enermax AIO products like the plague! They're total garbage mixed metal systems with no corrosion inhibitors or bio inhibitors in their coolant.)
https://i.imgur.com/98tnD0W.jpg
What case is that? I like it
Lian Li PC-V3000
http://www.lian-li.com/wp-content/up...3/v3000-03.jpg
If you plan on liquid cooling in it I suggest 54-60mm thick radiators. It's made for the thicker radiators and both the top and bottom mounting positions will leave large gaps if you use the standard 30mm thick radiators.
Thanks. That case is beautiful.
More shots please :clap:
https://imagizer.imageshack.com/v2/1...923/rW71lQ.jpg
https://imagizer.imageshack.com/v2/1...922/0IJc2P.jpg
https://imagizer.imageshack.com/v2/1...924/A7DNvM.jpg
https://imagizer.imageshack.com/v2/1...923/iKvx1f.jpg
Hardware:
Corsair RM850x 80 PLUS Gold
Asus ROG Crosshair VII Hero
AMD Ryzen 5950X @ 4.5Ghz SMT off
GsKill F4-3600C16D-32GTZNC 3600Mhz CL14
ROG STRIX RTX3080 O10G V2 GAMING
NVMe 2TB PNY CS3030
SSD Crucial MX500 1TB
2x HDD Western Digital Red Plus 14TB
Refrigeration:
Fractal Define 7 XL
Full Noctua Redux
Reservoir XSPC D5T
Alphacool VPP Apex Pump D5
Alphacool NexXxoS HPE-45 Full Copper 360mm
Bykski CPU-XPR-POM-M-V2
