That's a reallynice clock for a 8320
AMD A8-5600K at stock, stock cooler = 282 points, DRAM 1600 MHz cl9
http://i.imgur.com/usATjUm.png
AMD A64 3000+, socket 754 :), 2000 MHz CPU clock, DRAM 322 MHz, 36 points!!! :D
http://i.imgur.com/g1hV5tc.png
http://i.imgur.com/uJlPTfZ.pngCode:
C I N E B E N C H R 1 5
Name Score CPU CPU MHz Timings Brand ScreenShot
01 charged3800z24 1213 2x Opteron6272 2099 - AMD 01
02 Johan45 859 FX-9370 5338 7-9-8-24-33 AMD 02
03 FlanK3r 858 FX-9590 ES 5371 8-9-8-24-44 AMD 03
04 darkage 842 FX-8320 5267,7 8-9-8-24 AMD 04
05 I.nfraR.ed 838 FX-8350 5231 9-9-9-27-34 AMD 05
06 FlanK3r 815 FX-9370 5065,79 8-9-8-24 AMD 06
07 Daveburt714 813 FX-8350 5077,16 8-8-8-24-36 AMD 07
08 The Stilt 806 FX-9370 5000,29 10-12-12-24 AMD 08
09 chispy 802 FX-8350 5226 8-9-9-22-33 AMD 09
10 tbone8ty 754 FX-8350 4817 10-12-12-31-45 AMD 10
11 FlanK3r 725 FX-8300 4515 8-9-9-24-44 AMD 11
12 Karossua 720 FX-8320 4500 9-9-9-24 - 12
13 felix_w 677 X6-1090T 4422,85 8-9-9-27-37-1T AMD 13
14 justapost 662 Opteron 6348 2800 9 AMD 14
15 haylui 527 X6-1090T 3800 - AMD 15
16 MacClipper 376 A10-6800K 4800 - AMD 16
17 Daveburt714 304 A8-6600K 3880 9-10-9-28-37 AMD 17
18 Daveburt714 294 A10-5800K 3800 11-11-11-30-41 AMD 18
19 FlanK3r 282 A8-5600K 3600 9-9-9-27 AMD 19
20 ReKcOlNu 168 Phenom II x2 550 3308 9-9-9-24-33-1 AMD 20
21 Daveburt714 166 A6-3500 2100 9-9-9-24-33 AMD 21
22 justapost 165 A4-4000 4500,89 9-9-9-24 AMD 22
23 The Stilt 125 A4-5000 1500 - AMD 23
24 chispy 103 Sempron 145 4354,11 7-11-7-26 AMD 24
25 FlanK3r 36 Athlon 64 3000+ 1937,5 2-3-3-7-10-2T AMD 25
CineBench_R15 ScoreKeeper v1.0.0.2 - ?Edgemeal(2013)
update to the post #77
We have more AMD CPU models and new one weak score with old one K8 :). I hope guys as Stilt will show some crazy scores with the best chips and hope for more APUs or Phenoms II x4 or maybe older FX "Bulldozer" 81xx.
I'm still working with this 9370...
Not much of an improvement, but I haven't given up yet! :D
http://i30.photobucket.com/albums/c3...psa7e958c9.png
nice Dave :). You are now better with 9370. Unfortunately I have not time now for benchmarking :(. Or I have, but Im lazy (i must switiching PSU, SSD, GPU, RAM between Haswell and FX)
Nice run Dave, you'll find you can get higher clocks with less volts on that chip.
@ FlanKer There's always time for fun you'l just have to make up for it later. I wouldn't tear everything down for that either. I've been playing with PCM05 lately what a b**ch of a bench that one is. Very tweakable once you finally get it to run.
Worst. mount. ever.
http://i.imgur.com/09UbGZw.png
Will revisit after HOT
http://i.imgur.com/EszCmbN.jpg
http://i.imgur.com/VozBJFp.jpg
http://i.imgur.com/C2HmdmU.jpg
http://i.imgur.com/NvkPdKB.jpg
That SPD... :rofl:
At least you got some nice frosty pics! ;)
nice loud silence, first man here with LN2 R15 score :).
^thanks guys, can not believe the noises I heard from the Venom with this poor mount, I can only imagine the cracking under load is similar to benching GTX 580 under cold and I want no part of that:p: Any more than 1.68v was a no go, the screen would go black and then "s d" would appear on the post code reader.
I will revisit with a proper mount as this same cpu has run 6900 R11.5 on an MSI board (and lived) so it should be able to do so much more on the CHV Z.
Great run either way :up: You'll find this bench is a bit harder on the CPU than 11.5 is.
Il try this with my 9370 too, LN2. Around 22.11. at OC show :)
I can run (in ~10 days)on my 2x2419. Have to dig out spare HDD.
small update with moar
http://i.imgur.com/xepcggz.png
nice score!
you cna try few combination with higher HT link for higher score :) FX has no problem with 3200 MHz at air, so with LN2...
I just put the 8350 back into the main rig. Have a new rad set-up to take advantage of the winter chill and managed this http://hwbot.org/submission/2456270_ Scored 887 @ 5533MHz
1.8V? Wow....A bit risk for good score :)
This chip is really leaky, that's why I call it my little piggy. The water was also around -7c, have my rad outside now and colder weather is coming. I also got a 9.68 in cine R11.5 at almost 5.6G
Like they say if you're not living on the edge you're taking up too much space. Ha ha ha
Here's a link to some pics. Only difference is the rad is actually outside hanging off that window sill. http://www.overclockers.com/forums/s...&postcount=859
Ok, after longer time I was traveling to my parents and tested light Cinebenchs at 2 home PCs...
A8-5600K at 4000 MHz with BOX cooler and 1600 MHz cl9 RAMs
http://i.imgur.com/u1MTDs6.png
After I tried old good "gold" Phenom II 1090T, not at max, but with decent 1.475V, 4094 MHz CPUNB 24xxMHz
http://i.imgur.com/SNkx3jW.png
You do have to be nice to other peoples stuff, a shame I know but you can't break it.
Nice runs, if that 1090 had 2 more cores it would definately give the FX a run for it's money.
Nice topic, here it goes using 16GB LP Ram
https://apadsw.bn1.livefilestore.com...ax1.jpg?psid=1
is it good?
