Hello,
I am currently running two water cooling loops in my system, but I assembled and filled the loops in January 2012.
The problem is, I have been wanting to rebuild my current system for a while (based on the aging LGA1366) - since a year ago in fact. Therefore, I have repeatedly put off draining and cleaning my loops as I consistently felt it would be a waste given that I would be carrying out a complete revamp of my system within a short period of time (which never actually came) anyway - necessitating the dismantlement of the loops again. So now, I have been running the same loops with no maintenance whatsoever for over two years.
I have a solid plan to carry out the upgrade in June. Would I be OK to wait until then? I haven't actually noticed any problems temperature wise, or any other obvious issues. I'm just concerned there could be some hidden latent problem.
Any thoughts? In case it's relevant, these are the components in each of the loops:
-EK Supreme HF
-Swiftech NB Block
-Koolance RP452X2 res with D5 pump @ setting 1
-TFC Xchanger 360 radiator
-EK FC560
-EK 120mm radiator (forget the model name)
-XSPC RX120 radiator
Odai.
