found those in my colleague's desk ... They thought it was junk .:eek:
Have to love qualification sticks
l0ud_sil3nc3 - 5:56:953 - 50x100.1 - 1467.6 MHz - 9-12-12-17-108-1 - Z97 OCF - Corsair 2666 c10 2x4GB/Samsung - 2.15v - LN2 (-125c/+2c)
http://i.imgur.com/cjUNEeV.png
and RTL's
http://i.imgur.com/FMwCrZn.png
Tsai's pot just sitting on top of the Dom Plats, naked and uninsulated, hence why just a quickie run to test these out, will put some more time in it as it feels about a half second off.
http://i.imgur.com/RRXhGUs.jpg
:clap: Like it :up:
He he, that's the aim of the game :D real good to see 2933.
However I feel a full can coming my way....
http://i106.photobucket.com/albums/m..._whoop_ass.jpg
Some PSC on air cpu on water,not looking to be added on this one as I went just over cap 4003
http://i62.tinypic.com/260aeko.png
Update. :)
Impressive results from l0ud_sil3nc3, Splave, hiwa and Nick Shih! :up:
alex-ro - 5:58:297 - 50x100.1 - 1466.4 MHz - 9-12-12-21-110-1 - Maximus VII Formula - Corsair Vengeance PRO 2666 c10 2x4GB/Samsung - 2.12v - Air +25c Ambient
http://abload.de/img/snaphsot0002iek56.png
First shot on new mems,need to improve efficiency and lower RTL.
alex-ro - 5:57:891 - 50x100.1 - 1466.4 MHz - 9-12-12-21-110-1 - Maximus VII Formula - Corsair Vengeance PRO 2666 c10 2x4GB/Samsung - 2.15v - Air +25c Ambient
http://abload.de/img/557r9jug.jpg
So its been 6 weeks without Ln2,finally received some ln2 today,testing a new 4790K was quite hard to dial this chip in,is so different to any 4770ks Ive tested
Did finally get a pass but was loosing a efficiency towards the end of the session,board seemed to get quite cold on in this session so im guessing some moisture somewhere.
Had a couple faster runs a little earlier that should have just cracked the 54.9xx,will keep trying :up:
bullant - 5:55:266 - 39x128.3 - 1410.8 MHz - 6-10-16-21-64-1 - Z97 OCF - GSkill Pis 2000 cl6 - 2.23v - LN2 -160
http://i58.tinypic.com/2hib4oi.png
http://i57.tinypic.com/nbdicp.png
This was one of the faster runs,im thinking 54.9xx on this on
http://i58.tinypic.com/357hfg2.png
http://i58.tinypic.com/2r2tc83.jpg
Don't know if that's the correct thread.
Also don't know how is my efficiency with this G3258, since there are not many 4GHz runs out there.
Screenshot lacks AIDA numbers, so it does not qualify, thus not writing the info in the correct format too.
All air, 1.92V for the mems - G.Skill 2000C9 Tridents, PSC-X.
http://hwbot.org/image/1219703.jpg
Awesome runs Bully, glad to see the 125 strap working out for you as well.
The humidity down under looks intense right about now!
Don't think I have ever seen your rig so wet/frosted especially not the SATA ports or PCH heat sink :D
@ Infrared
here's one to compare:
2666
http://i.imgur.com/4My1ta9.png
2736
http://i.imgur.com/pbDeSah.png
Thanks, loud :up:
I can't run that tight and it seems I'm 1 second behind.
Anyway, it doesn't matter anymore since it seems my new cpu can't run 2666 and 2600 with PSC even with slack secondaries and tertiaries.
It's either the board or the IMC. I can't even run CAS 7 at 2400, while that's way too easy on Z77 + 3770K with these sticks :(
Wish I had any other brand board to try...
Thanks loud, yeah I've never had it frozen that much before,I say you are correct
So this has been my main pi drive for the last year or so, guess it's time to test all my mechanical drives.
http://i.imgur.com/q2qUNrs.jpg
Maybe this is why I'm so slow :p:
I use 10 year old sata 1 Seagate in my haswell test rig with lots of bad sectors and I don?t bother :D
Not really, you normally try to avoid that hdd is involved in 32M, I also don?t use ram disk if I bench on time, which I didn?t on Haswell anyway
CW is much faster using SSD than HDD. So if you do it like 100 times per month and save 5 mins each time, it amounts to ~8 hrs of extra free time that you can use :D :D
Performance and stability-wise I see no difference at all having recently switched from HDDs to SSDs.
