Sorry I had a long day, I forgot. :shrug:
59%
59%
m4 update:
424.0400 TiB
1382 hours
Avg speed 92.78 MiB/s.
AD gone from 111 to 110.
P/E 7397.
MD5 OK.
Still no reallocated sectors
Attachment 119592Attachment 119591
Kingston V+100
34.5081 TiB
128 hours
Avg speed 76.36 MiB/s.
AD gone from 168 to 166.
P/E ?.
MD5 OK.
Attachment 119590Attachment 119589
Next update monday afternoon.
279.64TB Host writes
Reallocated sectors : 6
MD5 OK
This session is a bit slower, 32.68MiB/s on avg (8 hours), SSDLife is starting to make sense, still needs another 4 days for "Last 7 days" to make sense.
M225->Vertex Turbo 64GB Update:
190.25 TiB
643.6 hours
MWI 10 (drops by 1 for every 50 raw wear)
4524 Raw Wear
118.85 MB/s avg for the last 16.38 hours (on W7 x64)
MD5 OK
C4-Erase Failure Block Count(Realloc Sectors) at 2 (Bank 6/Block 2406; Bank 3/Block 3925)
Attachment 119599
And to think this is actually 10K P/E NAND, so in reality my MWI is really technically at 55.
Also stated to hit MWI 0 at around ~212TiB (~233TB), but again technically it won't until ~422TiB (~464TB).
I'm really excited to see how far this one goes. Especially if it last significantly longer after MWI wears out like the others have.
Funny how the MWI is not really relevant as some drives live way past this value. And they say it is supposed to be really accurate or at least indicative of remaining drive life. Some drives can write much more after MWI is exhausted.
145.13 hours
127.8084 TiB written
40.94 MB/s
MD5 ok
05: 0
B1: 49
E7: 57%
E9: 70400
EA/F1: 131520
F2: 128
I'd say that it's pretty obvious that there is no LTT on the Force 40GB.
It's time to find out if this is the norm from Corsair and so I've ordered a Force 3.
282.70TB Host writes
MD5 OK
370TB. 85 reallocated sectors. MD5 OK.
Interesting to see how the Force 3 behaves next !
Multi-update...
C300 Update 1
293.63TiB host writes, 1 MWI, 4955 raw wear, 2048/1 reallocations, 63.25MiB/sec, MD5 OK
C300 Update 2
298.794TiB host writes, 1 MWI, 5044 raw wear, 2048/1 reallocations, 63.15MiB/sec, MD5 OK
SF-1200 nLTT Update 1
159.625TiB host writes, 110.813TiB NAND writes, 46 MWI, 1811 raw wear (equiv), wear range delta 3, 55.85MiB/sec, MD5 OK
SF-1200 nLTT Update 2
164.125TiB host writes, 116.719TiB NAND writes, 44 MWI, 1867.5 raw wear (equiv), wear range delta 3, 55.85MiB/sec, MD5 OK
Glad to be over the hump with the C300 and now I can report at any time, not just as close as possible to every 50 on the raw wear. Lots less VNC/RDC and random checks during the day now :p:
198.02 TiB
661.1 hours
MWI 7 (drops by 1 for every 50 raw wear)
4668 Raw Wear
116.73 MB/s avg for the last 19.4 hours (on W7 x64)
MD5 OK
Looks like I'll be hitting MWI 1 over the holiday weekend while I'm off work. Hopefully I'll be able to catch it (since I'll be at home) and post it. If not, then no update till I come back on Wednesday.
Attachment 119620
Really amazed to see the M225 cross the 200 TB barrier. Nice going ! Somebody on a forum was wrongly claiming that if they hit 10 TB it would be a miracle etc. due to the really high WA but it seems like you have the 50nm 10 000 cycles MLC NAND and upgraded the firmware so it now has TRIM and a better WA algorithm so well done to Indilinx drives !
Considering the M225->Vertex Turbo's WA is ~1.18x with TRIM enabled and with these test conditions, 500TiB wouldn't surprise me much.
Hey guys, I'm still running 100% compression. I was just wondering if you think I should switch over to another compression at some point and when?
132.7050 TiB written
41.04 MB/s
MD5 ok
05: 0
B1: 53
E7: 53%
E9: 76352
EA/F1: 136512
F2: 192
WOW really quite impressive the Indilinx has such a low WA while being such an early design compared to the likes of the Intel or Crucial ( Marvel ) controllers.
288.72TB Host writes
Reallocated sectors 6
MD5 OK
32.75MiB/s (64 hours)
138.1458 TiB written
41.07 MB/s
MD5 ok
05: 0
B1: 57
E7: 49%
E9: 83008
EA/F1: 142144
F2: 192
MWI 0 at 217.148 TiB (238.75 TB)
I had some crashes and ASU lost logging for some 1.602 TiB.
ASU stats for MWI 0:
215.546 TiB (237 TB)
702.3 total hours
5000 Raw Wear
112.26 MB/s avg for the last 45.46 hours (on W7 x64)
MD5 OK
Attachment 119671Attachment 119672
Attachment 119673Attachment 119674
Next udpate probably not until Wednesday.
Great work, now we see how tough my old vertex gen 1s really are :) :) :)
Oooo :) Another one depletes its MWI.
C300 Update
311.3TiB host writes, 5254 raw wear indicator, 2048/1 reallocations, 63.1MiB/sec, MD5 OK
SF-1200 nLTT (from earlier today--MWI hasn't ticked down in awhile)
171.13TiB host writes, 122.156TiB NAND writes, 41 MWI, 1954.5 raw wear (equiv), wear range delta 3, 56MiB/sec, MD5 OK
290.86TB Host writes
MD5 OK
35.41MiB/s on avg (17.5 hours)
