So I bought my high end memory, whats the best way to run it?
We all know there is more than one way to run memory, in fact really you could say there are 3 ways...these being:
1 Low speed tight timings
2 Mid speed mid timings
3 High speed loose timings.
Question is which one is best?
After testing the new DFI LP P35 we found it offered quite a few options that proved usable for the memory with a given CPU speed.
Most enthusiasts or gamers buying Intel CPU's now are going to buy a quad core CPU, with this in mind a QX6850 was used for this article but owners of the Q6600 should also get some good data from this as the 8 and 9 multipliers are available to them. Of course if you have a dual core its still relevant also as it all depends on what multipliers you have on the CPU.
Please also remember with using a quad core the available FSB range is somewhat limited, while the excellent LP P35 is able to push upwards of 470FSB we used a max of 458 with an 8 multi for round figure of 3.66GHJZ clock speed on the CPU, in fact 3.66GHZ is somewhat of a magic number as staying within 7 MHZ of this we were able to clock the memory 17 different ways, with hopefully results that prove one way or another which is fastest and which way is slowest.
Read the rest of the article here: http://www.ocztechnologyforum.com/fo...ad.php?t=30816
