Originally Posted by
NODO-GT
Mescalamba & mal1954
thank for your reply.
i want higher VTT but then i need very high voltage on memory, minimal difference is 0.35, but i found that 0.48 difference between memory and VTT makes system much stable. i sometimes system failed to boot with higher VTT and same DRAM voltage (difference 0.40), when i increased Dram voltage it booted and was quite stable... I'll increase CPU amplitude, PLL, IOH 1.1v to 1.3 (i have chipset on stock active cooling...). i'll try to find a way to increase VTT and make system stable.
and yes Command Rate was 1 :D and tRFC 92 :D
so for Overclocking (not 24/7 setup), G25 is best bios, thats what i wanted to know.
