Can anyone recommend fans with the same spec or something similar that I can buy today?
120x120x25mm 4wire (PWM), 150CFM, 12V DC, around 1.3A.
120x120x38mm 4wire (PWM), 150CFM, 12V DC, around 1.3A.
Thanks!
Thanks!
Ask here, more folks.
http://www.overclockers.com/forums/
CFM only tells part of the story. If you are using fans for a radiator with thick fins then you also need something with high static pressure. If it is just an exhaust fan on the tower then the CFM is important and you dont need much static pressure.
