950W Enermax Revolution85+ works fine with the Rev1.0 Board
1.0 is the first, then 1.1 etc
which mem is that? it might be because of the spd... there are a lot of memory kits that are rated 1600 or higher but only have an spd profile of 1333 to make sure the memory boots up the first time in case vdimm is low :)
you can use virtual XMP 1600 in the newer BIOSes :)
yes, some beta BIOSes are detected as P02 if they are based on P02... sorry it can be confusing if you dont remember what bios you flashed...
cool! im very glad to hear that :toast:
damn, thats a nice rig!
TRUE black? never heard of it, could you post some pics? :D
and the killer NIC, did you ever try any of those linux apps they released for it? i heard you can reprogram the xilinx cpu to do other tasks than accelerating the network?
added, thanks! :toast:
thanks a lot for checking the other psu as well man! :toast:
in the end i deserved the bump, took me a couple of days to update this thread, sorry :P
gr8golf, next time poke me via email pls ^^
you can use award winflash to flash the bios, thats what i use :)
pm me your email address and ill email you the tool and the latest bios :toast:
thanks! :toast:
I am still testing my PSU/board so it boots correctly since I have gotten all timing and voltages showing correctly. Often, but not always, I need to boot a second time from a shutdown for the board to post so it may just be something minor since there aren't issues during operation so I think PC Power and Cooling Turbo-Cool 860 Watt technically works with the board, it may just be me or something technical outside of 'compatibility'. Will do more tests and post if there is an incomatiblity issue after all.
I apologize for off-topic, but to answer Saaya:
TRUE Black (courtesy of Thermalright):
http://www.thermalright.com/new_a_pa...nical_spec.jpg
Killer NIC:
I've used a few apps myself. Most common are having an external drive pugged into it to download massive files to that drive while running other network/online apps without slowing your bandwidth, setup your firewalls on the card so they don't slow down your OS, setup manual controls to say what apps can use how much bandwidth and VOIP. It is much like a mini Linux computer on the card, so it does use Linux command prompts that you can enter yourself.
hmmm interesting...
and its not all that cheap... a physix cards cost the same or more and in the end turned out to be a pretty much useless gimmick :D
about the psu, there might be a compatibility problem if you have to reboot a second time everytime to power on the board...
but if thats the only problem then thats not that bad at least :)
ill add a note to that psu on the list, thanks for the feedback! :toast:
Yeah, I got the unlit debug codes when I power on from a cold boot so I bet it's the caps needing more juice or something as the fans turn on, etc. and I boot fine after a second try. Warm boots work just fine as well. Wondering if it's the PSU, compatibility, or the BIOS? Not sure if unplugging/plug back in the BIOS will help or not (disconnected/connected the PSU already with no changes) or if a BIOS update would change anything. Most likely, it's just the PSU/Board combo and I don't know what else to do but get another PSU especially if nothing else will matter, just the booting twice inconvenience.
Anyway, any insight is appreciated and may help me and others with the same issue as I've seen it a couple times on the forums now.
Corsair TX650W
I'm using a Zalman ZM1000-HP.
It works perfect!
Corsair TX850 also works perfectly.
Enermax Revolution 1050 been working great for me !, my ultra bit the dust, lol
Tagan 700W does NOT work w/ the Bloodrage. :mad:
Enermax Revolution 85+ 1050W work ok!
BFG EX1200 Thumbs up and Steady as she goes.....
Solid Running 2 pumps, 2 285gtxs, 6GB ram, i7 920@ 4.2GHz, Boreas Cooler, 3 120 Fans, 2 92mm, 2 sets of Cathodes, 3HDs, 2 DVD roms.
SOLID.
Hi, Antec True Power quattro 1000W It works perfect so far.... :)
No issues with my gigabyte Odin pro 1200, corsair 850tx, or enermax pro82+ 625.
Worked very very nice with : Arctic Cooling Fusion 550R and Cougar CM 1000W.
Dont work (no boot with this PSU) Xilence Linear Power XQ 1200W
Anyone know anything about XFX 750W?
Seasonic - will be fine :).
