Sorry man my English isn't good to understand all your message but if you meant my name - friends call me Aleksandr(Oleksand ukrainian) or Sasha ))
Ти повинен знати, коли тримати їх, знати, коли складаються 'Em
Знайте, коли піти, і знати, коли для запуску
Ви ніколи не вважайте тестів оцінки, коли ви сидять "на лавці стіл
Там буде достатньо часу для Порахуй "при розгоні робиться ....
[URL] http://youtu.be/kn481KcjvMo [/ URL]
Whauuuuu! Very nice retail Major! With this chip must be fun.
Improved a little
http://i.piccy.info/i7/8f9a1321dff80...52_235_500.jpg
@ Major
you most definitely are doing it right:)
interesting to see such a fast time at tCL9.
That's what I was trying to say !
Besides OS trim, right HDD & temp., need to find the best & comfortable divider for the chip to hit its' best 32m run.
Unlike 1024m, CL won't change things much for 32m
You should be able to get a better score, I'm sure !:)
Let's kick ass again, Bro
BTW, nice PI32m run there !:up:
my score is nothing special. Some Ivy Beidge will throttle down with high voltage. For example, My cpu wprime score is so worst over 1.85V. That means my cpu is too much heat with high voltage and cpu clock should throttle to 6.2 or 6.1. If you lower your cpu voltgae, sometimes your score is better.
I feel like there is definately something going on in these chips for sure, even on air noticing some strange behavior.
x48 is okay to 1.24v
x49 needs 1.4v
x50 needs 1.37v
Tried multiple times to boot x49 at 1.37v and no chance bsod every time.
Perhaps the voltage can be both increased and decreased depending on clock speed used?
depend on cpu heat, splave. I didnt pour LN2 to full pot when I start benching. full pot is only -180~-182. If you start from -160, pour LN2 to full pot. The temp will go to down a little bit colder. It will help your wprime score better imo.
ok..pick up yourself.:)
very strange
maybe it likes evens on certain motherboards?
http://i.imgur.com/acEDi.jpg
I bet that wil be a rather good one cold :)
MaJ0r That is one hell of a chip u have there and super 32M Run 4m 52.235s Super shocked 6.753Ghz Just total Carnage Love it!:up:
Indeed, must say once again you have golden chip :D
Yesterday I've tested some 3D at stock cooling )
My tweaking skill isn't good but one result not bad:
Attachment 126927
Attachment 126926
Attachment 126925
Attachment 126924
incredible chip that you have there. did you have to play with vccio/vccsa/cpupll much at all?
