Can you make me one to fit a 7970 with 2x tec and small rotated contact area to reach the gpu ihs
? If so I want one, cold on my 7970 would be awesome
:D
:D
What does die size have to do with the TEC? Thats what cold plates and IHS's are for..
Any of the owners can show any screenshots with some temp results under stress testing? The product is really intresting. Thanks.
More so LARGER dies will produce better results with TEC's. As it is most dies require a decently thick cold plate to distribute heat from IHS.
Larger die = more even heat.
I have some results:
2500k@5.2Ghz, 1.378 volts.
Idle temps : 27/28/32/27
Load temps: 65/72/71/68
Alle temps with these settings:
ambient: 21
Temp target : 20
idle load tec is 40%
load temp offcourse 100%
Cooling: 3x360 rad with 2x 560ti in loop.
That rad must be suffering trying to cool a TEC and 2 gtx560ti's in a single loop.... Any idea what your coolant temp is? Would be interesting to see how hot it gets during a full load run so we can see how efficient the TEC unit is working.
Just for a quick comparison, this is with the stock MCW-6500T with a single EK 360mm rad with GT's at 7V and single MCP355 with the Petra top, note the cold plate could have been tightened a LOT better but i've stripped the stock screws well three of them to be exact. I would've gotten much better results if i used two MCP's since the stock block is extremely restrictive and i was barely getting any water movement...
5200Mhz at 1.45V full load temps hovering in low 50's. It was a quick setup.
http://img194.imageshack.us/img194/1561/5200p.jpg
Uploaded with ImageShack.us
Very Very cool, I am Tempted to over a Dual TEC Controller, and a chiller.... With the chiller i assume i would need two pumps? (One Hot side and one cool side). Is the LCD back lit? Can i swap it out a blue LCD?
Does the chiller have a mounting bracket?
