too bad bad i ordered another 4x4 board:D and found a cheap ecs board on ebay with tophat flash module so im good for now
this is a single 8800gt and for some reason maybe my mb i cant fill all four slots
http://img112.imageshack.us/img112/1115/43531622wz6.png
http://img112.imageshack.us/img112/4033/10672714de1.png
i have to run to homedepot to get some insulation so i dont have to worry about condensation and then some real fun
Nice frequencies and nice cpu score too :)
You think you can push them much more?
Edit: Btw, read some old stuff on the internet, http://blogs.zdnet.com/Ou/?p=747&page=3
So then maybe DDR2 800MHZ should be possible? Have to test..Quote:
If AMD can switch to DDR2-800, then the scaling will probably be a lot better but most of the Barcelona class servers announced only go up to DDR2-667 except for Sun which supports DDR2-800
Almost 4GHz!
Keep pushing, msimax :cheer:
my chiller cant hold the temps or my dtek fuzions most likely. ill post a suicide shoot later
a little tweaking 8800gt single card im only 1000 points away from my sli score:D
http://img55.imageshack.us/img55/814...8172813ab2.png
almost there :rofl:
http://img378.imageshack.us/img378/3...8004036ta9.png
i need a volt mod or more cooling i canget 4.0ghz but it freezes before i can get a scrennie
http://img295.imageshack.us/img295/3...8010902nb4.png
cpu is scaling good
http://img76.imageshack.us/img76/412...8012938pl5.png
i got dual channel to work this morning so ill post numa scores later
Awesome score msimax !
4 K8 cores with NUMA goodness :D.
What was the problem with dual channel?And will there be SLI results ?
Good luck with the 4Ghz mark :)
i had different type memory had to play with slot config
also im debating trying tri sli with 9800gtx since their soo cheap or 2 9800gx2 from ebay or wait for 4870x2
Insane speeds there.:eek:
hey i have a bright idea, dont knock it till you thought about it, how about we start leasing cpus :rofl:
http://www.alwayslowest.com/AL/index...s&part=2642849
i might have to be the first here to do it:D
LOL! Nice way to test "the latest" cpu's. Wonder what they do when you kill a cpu when overclocking? Then you say: I didn't do nothing. :shrug:
nah you say my server/workstion doesnt boot anymore and i put my old cpu in and it works fine :rofl::ROTF:
Holy :bananas: msimax-man! 3.9G+ Talk about bussin a move on! :shocked:
Hi guys...
I've been away for long due to the university....
However I tried a lot of times overclocking these 2350s....
What are the results???? ....not good....
The same situation as some time ago.... nothing to do to breach the 230FSB....
I even tried to reflash the "old" 0.301 bios (like Kyosen) and changed the HT links from x3-x3-x1 to x3-x3-x3.... no way....
I tried registry voltage modification but nothing changed....
My system runs stable on 2.25GHz, but only under load :confused: ...
So the overclocking capabilities are only 12.5% for these B3 Opty 2350 form AMD..... And I can only say poor AMD.....
my memories are Reg PC2-6400, so i don't think that RAM is my problem...
I think that my run ends here.... :( sorry...
However any help is still appreciated.... :up:
Thanks to all for supporting me in these experiment! (WS=WS/B only bios...)
Hey MsiMax...
No way.... I even tried clockGen but I had no luck...
Even ClockGen Has the 230HTT wall........
sorry.. :(
Dude, those are insane clocks! Grats!
