http://img205.exs.cx/img205/4657/2922mhz4cj.jpg
Model: 3000+
Core: 0.09
Date: 0443
Stepping: CBBHD
Code: MPM
Mhz: 2922 mhz
Gain: 1122MHz
Vcore: 1,84v
FSBxMulti: 9x325
Cooling: Air Hyper6/tornado
Stable: testing
Model: 3000+
Core: 0.09
Date: 0443
Stepping: CBBHD
Code: MPM
Mhz: 2922 mhz
Gain: 1122MHz
Vcore: 1,84v
FSBxMulti: 9x325
Stable: testing
Great score :banana:
winnie 3000+ 0445
Model: 3000+
Core: 0.09
Date: 0445
Stepping: CBBHD
Code: RPMW
Mhz: 2820 mhz
Gain: 1020MHz
Vcore: 1,53v
FSBxMulti: 9x313
Stable: testing
winnie 3200+ 0449
Model: 3200+
Core: 0.09
Date: 0449
Stepping: CBBHD
Code: MPM
Mhz: 2888 mhz
Gain: 888MHz
Vcore: 1,84v
FSBxMulti: 9x320
Stable: testing
Originally Posted by $0m#0n#
Man what is u are other voltages DDR - AGP - NBV - SBV- HTV
deafult or high pls help me..
WOW wonderful pls help meQuote:
Originally Posted by johnnyliu3377
I use ABİT AV8 and AMD3000+
I enter bios change which voltage and DDR setings pls exactly info for me (NOOB)
I use now 1980 MHZ :(
so good stepping is CBBHD ?
What about week ?
Model: 3500+
Core: 0.09
Date: 0501 (I50173)
Stepping: CBBID
Code: EPMW
Mhz: 2705 mhz
Gain: 505 MHz
Vcore: 1,69v
FSBxMulti: 11x246
Cooling: XP 90/Tornado
Stable: Super PI, 3D Marks
Model: 3500+
Core: 0.09
Date: 0501 (I50837)
Stepping: CBBID
Code: EPMW
Mhz: 2564 mhz
Gain: 364 MHz
Vcore: 1,53v
FSBxMulti: 11x233
Cooling: XP 90/tornado
Stable: Super PI, 3DMarks
Model: 3200+
Core: 0.09
Date: 0450
Stepping: CBBHD
Code: UPDW
Mhz: 2660
Gain: 660
Vcore: 1.55v
FSBxMulti: 266x10
Cooling: XP 120
Stable: yes (Superpi and gamestable)
Model: 3000+
Core: 0.09
Date: 0445
Stepping: CBBHD
Code: SPBW
Mhz: 2835
Gain: 945
Vcore: 1.45v
FSBxMulti: 915x9
Cooling: XP 120
Model: 3200+
Core: 0.09
Date: 0447
Stepping: CBBHD
Code: UPCW
Mhz: 2700 mhz
Gain: 700 MHz
Vcore: 1,65v
FSBxMulti: 10x270
Cooling: XP120/Papst
whoohoo i love this chip! :D :banana:
Model: 3200+
Core: 0.09
Date: 0449
Stepping: CBBHD
Code: GPMW
Mhz: 2550
Gain: 550mhz
Vcore: 1.50v
FSBxMulti: 10x255 mem=1/2 ldt 3x 765mhz HTT (havent tried 4x ldt yet)
Cooling: stock
Stable: still testing (prime95+2k5 for 2 hours so far)
this is what it does at stock volts btw, might be interesting for some people :)
Model: 3200+
Core: 0.09
Date: 0449
Stepping: CBBHD
Code: GPMW
Mhz: 2400
Gain: 400mhz
Vcore: 1.40v
FSBxMulti: 10x240 mem=1/2 ldt 3x 720mhz HTT
Cooling: stock
Stable: 2 hours prime95+2k5
Model: 3000+
Core: 0.09
Date: 04/44
Stepping: CBBHD
Code: XPDW
Mhz: 2430
Gain: 630
Vcore: 1.52
FSBxMulti: 9*270 (no divider ram at 2.5-4-3-7)
Cooling: Air XP-90 Med Speed Panaflow 92MM
Stable: 15 Hour Prime stable, SuperPi 8M Stable
Screenshots to follow
Edit:
Got this bad boy stable at 2.5-4-3-7 at 280HTT ram at 1:1... looks to be a decent chips (700MHZ gain on a 1.8GHZ chip makes me happy) (on 1.536 Vcore)
nice chip saaya, it's very interesting to see the max with the x10 multi :D
BTW, does it shy from Sub-Zero cooling?! :banana:
havent tried yet, but i already modded the swifftech mcw371 to fit on a socket 754/939 board :D (swiftech heatsink with 80W tec)
this thing is really old, its for socket a and this old intel p3 socket :D
since those winnies are running that extremely cool it should be fine if i keep the vcore low :)
on a german hardware site they just meassured a 3500+ winchesters power conumption, with cnq in dile its only 6W!!! and max load was 40W!!! im not 100% sure those numbers are correct, but it makes sence to me, the retail heatsink is really crappy, the fan doesnt move much air, yet the heatsink stays cool to the touch/slightly warm even at 2.5ghz with 1.5v under load.
so an 80W tec should be fine :D
enough OT :D i will make a new thread about the results with my tec tomorrow :)
can you please post some screenshots and an orb link?Quote:
Originally Posted by reLo
sorry, but i find it rather hard to believe its stable at those speeds with that cooling and only 1.45v
Model: 3500+
Core: 0.09
Date: 0451
Stepping: CBBID
Code: FPAW
Mhz: 2700 mhz
Gain: 500 MHz
Vcore: 1,55v
FSBxMulti: 11x245 (2-2-2-5)
Cooling: XP120
Stable: 3DMark
ok here is mine
Model: 3500+
Core: 0.09
Date: 0437
Stepping: CBBFD
Code: VPAW
Mhz: 2750 mhz /2700mhz /2700 mhz
Gain: 550/500 MHz
Vcore: 1,6v/1,56v/1,56v
FSBxMulti: 11x250 (2-2-2-5)@Twinmos UTT@3.1V /10x270(2-2-2-5)@ Twinmos UTT@3.6V / 9x300 @ Gskill @ 2.9V
Cooling: hyper6+tornado
Stable: full stable 24/7 setup
Comments
max stable for validation 2905++(did try this only one time) , max post 3GHz
bench mode is 11x255 (2-2-2-5) @twinmos UTT @3.1V @ 1.71Vcore (full bench stable)
http://valid.x86-secret.com/show_oc.php?id=4636
Model: 3000+
Core: 0.09
Date: 0445
Stepping: CBBHD
Code: SPMW
Mhz: 2520mhz
Gain: 720mhz
Vcore: 1.46v (1.5v in bios but undervolts on neo2)
FSBxMulti: 9x280 (2.5-3-3-10) 133 divider with 2x512MB OCZ PC4000 rev2 gold
Cooling: Venus 12, 80mm fan @ 2300rpm
Stable: full stable 24/7, F@H running for over 1 week
Comments
max stable into windows: 300x9, 1.65v
Originally Posted by saaya
this image only 1 M test when i willl find 32 M test screenshot i'll post it here.. :banana: :banana: :banana:
cool, can you post a 3dmark 2005 link? :D
sayaa , ı've same cpu 0445 spbw...
3dmark 2001 orb#2 5950u with 0445 spbw 3000+ winch. :D
http://service.futuremark.com/compare?2k1=8414583
http://img163.exs.cx/img163/5167/16vq.jpg
wow!Quote:
Originally Posted by Brandybuck
have a pic or some more infos about that waterbox thing?
last night i opened the window and let in some cool air and i could reach 2.6ghz stable with only 1.500v wich was actually 1.472v according to CPUZ and 1.485v according to CBID! :slobber:
im not at normal room temps, to get it stable at 2.6ghz i need 1.525v now (1.504 according to CPUZ and 1.517 according to CBID)
cooling is the amd stock heatsink with a small 60mm papst fan on it. its a high pressure high speed fan, but it has only 35cfm! :eek:
i cant wait to see what i can get out of this chip with better cooling :D
3200+ winchester dik4bi cbbhd 0449 gpmw 10x260 1.500v
2x256mb twinmos 3200 bh5 2.0-2-2-5-8-16 2.6v @130mhz (using the 1/2 mem divider to find the max cpu oc)
leadtek 6600gt extreme @stock (550/1125)
http://www.xtremesystems.org/forums/...id=25746&stc=1
sayaa ,
2835mhz air cooling stok heatsink.. :D
http://service.futuremark.com/compare?3dm05=528466
waterbox : water chiller.. :D made by my friend arbiter... :cool:
