Awsome pictures dude. How you get your tubes so clear? Mine are all cloudy, not used or anything.
http://sites.google.com/site/apokalipse/wc.JPG
I discovered the hard way that my Thermochill PA120.3 doesn't use G1/4 threads when I put in my compression fittings.
Also, I'm tempted to get a GPU block for my 5870.
Though I'll probably get a new board first. This one isn't that great (M4A79XTD Evo)
Apokalipse: why not turn pump 90deg in horizontal plane so that it's pointing to cpu block? One 90deg fitting less ..
Also switch rad inlet/outlet and put stright or 45deg rotary for 2nd tube of cpu wb to get rid of last 90deg. Though of course, there is no actual need in such low restriction loop with high flow pump for even more flow .. just my bad habbits to improve things to ideal :D
@supercopa and @ Vlad'sAPE your rigs are MDPC worthy :) let get some submits here
Apokalipso, That's a LEAN looking loop. did I get it right: Y splitter before CPU: = T line and thats it? no res? whatkind of temps you are getting?
That could work. Though rotating the pump would probably be difficult to do.
Mind you, if I get a waterblock for my 5870 it would probably be better to keep the right-angle fitting there.
Yep, just the fillport.
Core Temp reports 30-33ºC idle, but I don't think it uses the right TJmax value for Phenom II's (I think it's about 10ºC too high).Quote:
:shocked:
YOUR BUILD IS JUST AWESOME! :up: :clap::clap::clap:
You MUST post more pics of your build Vlad'sAPE!! We Want More!! :mad:
:D
EDIT: PLEASE DO NOT QUOTE IMAGES !!!!!
Vlad - may I suggest you start a thread either in the Liquid Cooling Section or the Work log section, so people can ask their questions, and you can show us more photos of your most interesting build as you complete it. Thanks, shazza
Vlad'sAPE! I love what you did there!
Please show us more. I am very interested to find out how you fitted all that rad.
The rear exhaust is a NZXT FN 120mm fan. I was really surprised because its darn cheap (6€) and it even comes with the wire sleeved (and the quality of that sleeve is not bad at all). The looks aren't bad either, and it looks quite white: its not milky, though, but its not greyish. But....although it looks not cheap from outside, you just can't compare it to any other decent fan (Scythe GT, Scythe S-Flex...) as it sounds weird for its speed (1200rpm) but maybe its just mine that seems not well balanced. For 6€ its not bad at all, deffinitely...but for such an astonishing build of yours I think you should aim little higher, although sometimes finding the proper color fan its quite hard :up: BTW, need to see how you are doing in your worklog :up::up:
Componentes are:
-CM 690 II Advanced
-HWlabs Black Ice GTS 240 Lite
-EK Supreme
-EK NB/SB 5
-EK Bay reservoir
-EK X-Top D5 Rev.2
-Laing D5
-Primochill Red 1/2" tube (I wanted white...but cound't find)
-TFC 1/2" and 45º compression fittings (wanted Bitspower but too expensive in Spain :rolleyes: )
I'm sending you some images for PM as I don't know if i'm allowed to post some more in this thread :cool:
My Humble rig in progress, still good ol' S755, but it's powerfull enough for what I ask from the system.
Still working on it, fans on the triple will get replaced by Scythe GT's 1850rpms, th Original psu for this one will be sleeved so my allready sleeved HX750 is hanging at it and no cable management at the back :D
and I've got a Supreme HF Nickel waiting to get installed next week ... :)
http://i40.tinypic.com/993wae.jpg
http://i44.tinypic.com/2uemt4x.jpg
http://i40.tinypic.com/xgl34w.jpg
http://i40.tinypic.com/28m24hd.jpg
Wow, I certainly have missed a lot in these past few days...
Loving the new stuff from everyone! :up:
I think it would be nice if everyone could just post a link to any sort of worklog or documentation they have because there will always be questions...
@Vlad'sAPE... Wow. :up:
Man, if I didn't know better, I'd swear you were using glass or polycarb in lieu of standard tubing.
Single XSPC 120mm Rad, the tuned version of Corsair H50 setup.
http://img.techpowerup.org/100415/DSC00494.jpg
http://img.techpowerup.org/100415/DSC00498.jpg
http://img.techpowerup.org/100415/DSC00500.jpg
http://img.techpowerup.org/100415/DSC00501.jpg
http://img.techpowerup.org/100415/DSC00507.jpg
Hope you liked.
There are some... Orgasmic... Builds in this thread, I wish I'd checked it sooner :eek:
you guys sure have some nice build.
true high flow water cooling
http://www.abload.de/img/dsc06777s50n.jpg
Hi guys. My rig isn't really complete, but here are some pics. Sorry for their quality.
It's Gigabyte X58-UD5, i7 920, Sapphire 5850 (now i'm working on my second 5850's bios and next week I'll put them in crossfire)
WC setup: EK fullboard set, EK fullcover (waiting for one more), Stixion i-300 on cpu (waiting for EK Supreme Highflow),
Laing DDC 18W + xspc (secod is ready, maybe I'll use him), two TFC Xchangers 360 with TFC Xtenders and noctuas P-12,
Swiftech QP 320 and akasa fans, Reservoir is custom made from liquidtech.cz
http://lh6.ggpht.com/_XJqfx56HOgE/S8...0/IMG_0620.JPG
http://lh4.ggpht.com/_XJqfx56HOgE/S8...0/IMG_0625.JPG
http://lh4.ggpht.com/_XJqfx56HOgE/S8...0/IMG_0628.JPG
http://lh4.ggpht.com/_XJqfx56HOgE/S8...0/IMG_0630.JPG
i'm out of on some business trip in Indonesia, i'will do some more shots once i get back..really appreciate y'al responses and support..but this trips really draining me right now :(...wil comeback pretty soon...
My 1st custom WC rig ever, big thanks to Utnorris for the guidance and support. :D
http://img695.imageshack.us/img695/5699/img0963d.jpg
http://img215.imageshack.us/img215/7414/img0843w.jpg
Very nice job, iTravis :up:
Love your rig Vlad... It looks amazingly industrial
