evaporator can't transfer heat fast enough ??
Hello
The unit i have can handle easily 250w -38c load at evaporator outlet .
When i used the system to cool heavily overclocked old Qx6700 with high voltage the cpu temp was always under (-15c under load) .
now when i testing 3770k (cpu delided) (5.4 ghz and 1.35v) i am getting cpu temp (+30-+40c under load . mount was perfect) , i checked temperature of evaporator outlet (-40c) , evaporator base temp -10c .
This mean the evaporator can't fast enough transfer heat .
what solution , use another evaporator ? .
the 3770k at those speed is under 200w load , so i think captube adjustment is out of question , the unit have already more than enough capacity for the given load and the evaporator outlet temp is -40c .
Note evaporator i have is from a vapochill ls .
