Looking for feedback on my quad sli/cf phase change plans
My plan is to take four 10k window ac units that I got for free and cut the evaps and condensers off and replacing the condensers with plate heat exchangers and then running water loops outside the windows of my apartment using high flow pumps and 9x120mm rads to cut down the footprint on my desk as well as removing the massive heat source from my room. Is this a viable method of doing this or will I run into other issues from this? Second question, will using a long lineset have a big impact on the performance I am thinking of doing two of them with 5 foot ones and two with 8 ft so i can space them out a little more on either side of the bench table.
Thank you,
Chris
Sorry for the two threads in two days
Parts list so far
Reducing Coupling to connect the suction line to the compressor
https://www.supply.com/browse?refine...xoCdjgQAvD_BwE
This is what I am currently planning on using as a suction line but I am open to suggestions for alternatives
https://www.homedepot.com/p/HOME-FLE...0525/203073939
I got a 5 pack of SUD 111's for 15$ and they should do well enough as a filter dryer.
For the evaps I am planning on making them out of a 2" diameter 6-inch bar of 110 COPPER ROUND on a lathe and then adding surface area with a dremel like ron did on the chilly1 for the under-the-ice units
