Could a bad CAT5 cable result in 10Mbs network speed?
After wrestling with ultra slow internet speeds I finally noticed my Speedtest results were seemingly hard limited at 10Mb/s.
Long story short, I believe I have isolated the problem to the cable or connection of that cable. Is that possible?
I've tried 3 systems at the location of the slow PC (sadly it is my main rig ) and all of them auto-detect at 100Mb/s for a second, disconnect, go back through "Identifying" and re-connect at 10Mb/s Full Duplex. Manually setting 100Mb/s Full Duplex results in no connection.
All 3 systems and the router port are verified to auto-detect at 100Mb/s on other cables.
Odd thing is, I've been running fine for a few months with this (long, 100 foot) cable and getting my normal download/network speeds. It is a recent issue that has come up. Potential that one of my cats damaged the cable slightly or I'm not sure what else could be causing the problem.
Could a bad cable really be at fault? I don't want to order a new one if it doesn't make sense, not to mention routing it through the basement was a PITA the first time. My office is on the other side of the house as the router.
