Originally Posted by spaceman
I'm using the same fan in my 510 Deluxe. No you can't use the existing wires feeding it, they don't send enough juice. I just ran the fan wires through one of the fan's mounting holes, then back into the puter case, and spliced on a molex. Works great, you'll get MUCH better airflow, but you just have to be a little more careful if you pull the PSU again. I always leave the side off my case, but if you run the new molex through a PCI slot, it should be easy enough to work with. :cool:
