Are these as efficient as the reviews say? Power wise cause looking at the reviews it seems like my 620 watt psu would be able to handle it
i installed the backplates today they look awesome and heat went down even tough they are crazy cool cards :)
http://img192.imageshack.us/img192/1...0428120735.jpg
http://img716.imageshack.us/img716/6...0428140959.jpg
Uploaded with ImageShack.us
backplate is good
Damm I so want two of those sexy cards lol :up:
thanks mates
yes this are reference card i just put the backplates :)
benching in garage with 40F temp
http://i.imgur.com/horwg.jpg
not bad ;) load temps around 35c 1.45v
hello:)
my 3dmark11 in sli Attachment 126195
low score physx : (
Lower memory frequency and tighten timings will help physics :D great score though still, very nice scaling in sli :)
Hi,
great score Simous .
thanks for your coment ;) :) , the physx score in low because i have 2x4go and with 4x4go better score , i think
congrats all for the nice results :)
http://youtu.be/QPGGGeE4reA?hd=1
Simply amazing card, just finished my review on it :)
nice epic: Up: good card : Yepp:
While I was fleshing out all of my GTX 680's to find which was the best over-clocker I found out I have a beast card. I always wondered why this card all the way at the end in my 4-way SLI config operated so much cooler than the others. It is crazy efficient.
1328 MHz core, 3580 MHz memory at stock voltage! Also EVGA Scanner X and OCCT stable at these frequencies. My other three GTX 680's would top out around 1240-1260 MHz core when used on their own.
This core is so efficient it idles at 18 C! Anyone else see clocks like these? It will make a nice single GPU for my new mini-build.
http://www.youtube.com/watch?v=th4pN...ature=youtu.be
Hello callsign
you have a very good graphics, very fast board, 1328mhz it is the frequency gpu-z or the frequency reality?
You got some artifacts dude, need more juice.
Great card anyway :yepp:
How could you tell that?
Guys, I don't see many of you going for water cooling, but does anyone know which water blocks work best on these? Does the cooler split like a 580 so I can leave the backing plate on and use a VGA-Supreme?
Splave - great work as always.
:up:
sweeeeet
Nooooo nooooo...
Today I tested my new toys.
First one 1325Mhz (with boost) no problem. :clap:
Second one ONLY 1200 (with boost) :rolleyes: :mad: :shakes:
This is not happening :down:
I will try to flash BIOS from the first card. Probably will not help. But...
How can i flash BIOS? Is the procedure the same as on the GTX4xx, 5xx?
@andressergio
Can you please test 3DM11 on 5000Mhz and 1st card 1300/500, 2nd card 1200/500. And then both on 1200/500.
Thx
