I want my next WC setup have more of an industrial look. Instead of plain old plastic tubing I was wondering if I could used flexible copper pipe with flared fittings. Could this be done and where can I get male G1/4" to male flared adapters?
This has been done, but I'm not sure where you'd get the adapters. Home Depot / McMaster?
You have to be familiar with soldering copper.
It has been done several times before, but keep in mind that changing hardawre will become a pita.
I want to use flared copper pipe to avoid soldering. I've refitted flared copper pipes for propane ovens and heaters in RVs so I know how to make them air tight under pressure.
:confused:Quote:
Flexible copper pipe?
Like the suction lines you use for phase, goes between the evap and compressore, can get copr or stainlels steel
If you lived in the S. Florida area, my auto parts store has all the brass/copper fittings you would need. If you want the name of the place is Congress Auto Parts (www.congressauto.com) number is 1-561-793-2245 and ask for Jim. He should be able to find the fittings, and get them shipped.Quote:
Originally Posted by AllAgainstPaul
Soft copper looks like crap. It is not until it becomes "hard drawn" that it is proper for bending (with a real tubing bender) and will give you that "Industrial" look that you seek.Quote:
In a previous life I did Industrial Instrumentation and bent my share of copper and high grade stainless steel tubing.
This guy did it too(dutch forum):
http://gathering.tweakers.net/forum/...05117#27305117
Originally Posted by barzi
That looks so cool. How much would all those 90° bends affect the flow?
As bad as normal hose i belive not sure as when you think of all the bend in your home and one pump to move it and it doea at some speed...
Lets not forget that copper pipes in your house also have the added advantage of having ~100psi of pressure to push the water through, something that I found out the hardway when I used ClearFlex tubing on my automated float system on my Bong Tower the result ruptured ClearFlex-->Quote:
Originally Posted by Pete
http://www.myfoto.com.au/Photo/snapp...ew/Picture.jpg
I agree with the bends offering as much resistance as plastic tubing though.
As for bending these, Bending Springs is all you need IMO (my mate is a plumber these things work a treat hehehe)
External Spring
http://www.diydata.com/techniques/plumbing/exbender.gif
"External springs are for smaller diameter copper piping ( from 6 to 10 mm external diameter). Again they are made from flattered steel but with a 'funnel' at each end so that the copper pipe can be fed through the centre of the spring. With the spring surrounding the pipe, the spring prevents the wall of the pipe from spreading outwards as it is bent. As with the external springs, each pipe size requires its own specific spring."
Internal Spring
http://www.diydata.com/techniques/plumbing/spring.jpg
" Internal springs are just a spring made from flattened steel with a taper at one end (which is inserted into the pipe) while the other end incorporates an eye. With the spring within the pipe, the wall of the pipe is prevented from collapsing inwards as it is bent. Internal bending springs are commonly used for copper pipe from 12 to 22 mm external diameter (larger springs are available but are not recommended). A specific spring is required for each size of pipe being bent."
Hope this is of some help :-)
Best of luck with it.
Wow that hose didn't half go some...it still all slealed just strectched
Nope not sealed it split and water floooooowed freely LOL...luckily I wasQuote:
sitting at the Cooling Tower at the time and turned the inlet tap off to the
tower and avoided a wet mess...replaced the hose with re-enforced
variety and problem solved ;-)
Hope it works out for you dude, i have tried reading ya topic but bongs other than smoking off are way too complex for me
LOL yeah 7 seperate loops in a watercooled PC is easier :-PQuote:
Is all finished actually gets ~6 below ambient water temps and IMO looks the part :-)
LOL 7 loops is easy but also not so easy...trying to work out soemthing big in a differnt topic which you might be able to help on, have a gander in wc about presure gauges.
It's -5c outside right now, wish i could go bench my unit now, sub ambiant cooling heheh
These are the benders that I use...
http://www.ridgid.com/Tools/500-Series-Lever-Benders
That looks like a nice pipe bender but ouch is that expensive!
Those springs aren't worth a rip if you are trying to make tight bends. They just don't work well on anything other than gradual bends.
I've seen mixed results from Copper-piped systems... some run cool as anything else, others run drastically hot... reasoning? Metal : Coolant surface area increases. If temps INSIDE the case are above your coolant temp, then the copper piping serves to heat up the water slowly... If temps inside the case are LOWER than coolant temps, then the copper piping serves as a mild radiator.
Flare fittings: just look for ones with a 1/4" BSP thread and use PTFE tape - more likely to find those than rubber o-ring'd G1/4" fittings.
Or like this http://www.xtremesystems.org/forums/...4&postcount=46
Solid tubing. I would imagine it would take a while to get all the bends perfect.
I am in the process of overhauling my rig. Adding a triple 120 to it now with some nice fans.
Water temps don't break 32c after 24hours in a furnace of a room I have @ 26-28c all the freaking time.
EDIT: Here is the link--> http://www.xtremesystems.org/forums/...ad.php?t=84904
Now that is the cleanest looking water setup i have seen in quite some time 10/10Quote:
Originally Posted by smopoim86
Can anyone actually see the pictures for this thread:
I remember seeing a great hard tubed rig, but now it is gone or not loading anymore.
Wasnt loading for me.
