http://i.imgur.com/eXhXF.png
Thanks. I originally had a dual bay res but it didn't fit properly and vibrated the whole case to bits!
Some more pictures of how its setup in the front.. pretty tight fit, I almost managed to tighten all the fittings without cutting a hole into the top!
http://i.imgur.com/U9zUW.jpg
http://i.imgur.com/duroy.jpg
Yep! I know its overkill, I intended to cool the GPU and board but turns out there aren't waterblocks for either of them. Using Thermalright X-Silent 120/140s at low speed.
http://i.imgur.com/gXXT7.jpg
This is my new build, fully watercooled ultra-quiet machine.
Chassis: CM690II Advanced
MB: ASUS M4E-Z with EK-FB
CPU: i7 2700K with EK-SupremeHF
GPU: HD7870 with EK-FC
Memory: HyperX2133 2GBx4 with Bitspower GalaxyFreezer
PSU: Super-Flower SF500P14FG 500W fanless with KOOLANCE HD-60 water block
RAID: RocketRAID2720 with KOOLANCE GPU-210 water block
HDD: 4xWD30EZRX-3TB,4xHGST-4TB with Silentstar HD-Quad Core Rev.2
HeatExchanger: Koolance HXP-135 (exchanging heat with cooling loop chilled by outdoor car radiator)
Radiator: BlackIce GTS240 (only for emergency)
Pump&Reservoir: D5 with EK-D5 X-RES
SSD: 2xC300
Thermo Controller: T-Balancer bigNG
http://vladi.cocolog-nifty.com/photo...newsub10_2.jpg
http://vladi.cocolog-nifty.com/photo...1/newsub11.jpg
http://vladi.cocolog-nifty.com/photo...1/newsub05.jpg
http://vladi.cocolog-nifty.com/photo...1/newsub04.jpg
http://vladi.cocolog-nifty.com/photo...oling_loop.jpg
wow... that is xtreme!
http://i46.tinypic.com/kdmsg0.jpg
a little something something!
That looks like a little more than something, that looks flippin amazing. Show us more pics please
This is my latest build, need to swap out the blue 8-pin i found in a box :)
Cooling:
EK XTC 420
EK XTX 240
EK Supremacy Acetal
EK D5 CSQ Top together with Alphacool VP655
Phobya 150mm reservoair
EK 7970 FC block
16/13 tubing
EK Bloodred water
http://img687.imageshack.us/img687/2403/img1286oz.jpg
Uploaded with ImageShack.us
Will add fans to the top radiator when i figured out if i should go with Corsair AF-140 or Bitfenix Spectre Pro 140 White Led
Nice ante_ante!
Will have new pic?s of mine, as sone as i get well (halsfluss)
nice builds guys!!
@ k.3nny : can you tell us what kinda tubing and fittings did you use ?
Now I feel healthy, so here are some pictures of the updates.
Bitfenix Spectre Pro on both side of the 420 rad.
EK - ASUS M5F block (just mosfet block)
http://www.conman.se/red/1.jpg
http://www.conman.se/red/2.jpg
http://www.conman.se/red/3.jpg
http://www.conman.se/red/4.jpg
Xtremly nice build u got there Conman :)
@CoNMan --> Sometimes the LED light system in a case can be a hit or miss, but with your color selection it looks great in your case!!! Is that a grey or white LED?
Sorry, kinda color blind which doesn't help for picking color themes for a system! The dark red makes the case look much more evil due to not being able to see many of the components other than the red tubing pumping fluid thru the beast!
Thank you ante_ante and fuzelogic
The led is nzxt white led strip.
Awesome machines, guys, really! :up::clap:
